Results 21 to 30 of 35
Thread: Rotor Sizes
  1. #21
    Apr 2010
    South Morang, Victoria
    Quote Originally Posted by Umai Naa!! View Post
    RDA, etc you get what you pay for.
    You wouldn't recommend RDA?
    Just wondering if I really need to replace the rotors.
    The front rotor has a 1.5mm lip on the outside and a 2mm lip on the inside.
    Is this worn enough to replace, or do they have a little more life left in them?
    They have done 75,000kms.
  2. #22
    Apr 2017
    belgrave victoria
    Personally i would replace rotors every time i did pads its not that much more than having them machined
    Rda is Chinese made and some have good reviews and some bad so i steer clear
    Go ate or zimmerman ect a bit more but peace of mind after all they are the only thing that will stop you from having a crash!
    2017 Golf Alltrack 135tdi All options
    19 inch Brescia Wheels Golf R brakes front and rear
    Calipers painted Candy apple gold
    New rear sway bar and linkages
  3. #23
    Mt Cotton
    Quote Originally Posted by blaast View Post
    The discs if originals are pretty soft metal I was told that VW like to make them that way so as to give a certain "feel "to the pedal pressure , 1.5 mm is not a good amount to leave on the van , rotors are getting cheaper these days and as Kachingg said replace them with the pads for safety and peace of mind . The last set I bought from GSL Rallysport have lasted close to 100000 kays so far and are still in good condition .
  4. #24
    Dec 2008
    Sydney/Canberra
    That means they're at least 3.5mm thinner than new.
    I'd still replace them.
    The likes of RDA, DBA, and the like, are a harder steel which is great for longevity, but will knock the edge off the braking perfomance, as well as being quite prone to brake shudder once they've had some heat in them.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
  5. #25
    Aug 2016
    NSW
    I've got DBA solids on the front after their drilled and slotted discs warped after about two weeks.
    The solids are fine with softer pads and I hurtle down Bulli Pass every day.
    2018 Crafter Runner
    T5.1 6sp manual.
  6. #26
    Adelaide hills, SA
    I didn’t have any problems with the DBA disc on my T5 4mo. Though the RDA discs lasted max. 20,000km so, I wouldn’t put the RDA and DBA in the same bag, they’re definitely better quality product and I didn’t notice any changes in braking performance.
  7. #27
    Apr 2010
    Which of the following options would you recommend for front and rear rotors and pads?
    Option 1:
    From imparts.com.au, Textar all around = $865
    Rotors
    • Front: $330 pair
    • Rear: $286 pair
    Pads
    • Front: $131
    • Rear: $118
    Option 2:
    From HSY (hsy.com.au), ATE all around = $915
    Rotors
    • Front: $319 pair
    • Rear: $293 pair
    Pads
    • Front: $151
    • Rear: $153
    Option 3:
    Recommended from Brakes Direct, Total = $594
    DBA street series OE rotors
    • Front: DBA2242 $220 pair
    • Rear: DBA2247E $150 pair
    QFM HPX pads
    • Front: DB1947HPX $109
    • Rear: DB1956HPX $79
    Option 4:
    Brakes Direct, Total = $704
    • Same as Option 3 except front DBA 4000 HD series rotors, DBA42242 $330 pair
    Or other recommendations from this list at Brakes Direct:
    Search results for: 'vehicle'
  8. #28
    Apr 2010
    Which of the following options would you recommend for front and rear rotors and pads?]
    Just hoping I can get a few votes on the best rotor and pad option listed above, as I am being indecisive!
    I'm not too concerned about cost since it is only $320 between the cheapest and dearest option, but is the dearest option the best?
    Thanks in advance.
  9. #29
    Apr 2017
    belgrave victoria
    I have got ate ceramic pads and zimmerman discs (same quality as ate) and am extremely happy with them price is pretty much what you have been quoted that is the option i would go for personally reading around the forums ate has a good solid reputation and is recommended by some of our mechanic forum members
    If you want longer wear and don't track your car or thrash it every weekend up in the hills consider ate ceramics last almost twice as long kinder on rotors as it puts a buildup of ceramic on the rotor so its ceramic vs ceramic for braking they have a nice feel to them just be aware they have about a 500 kilometer wear in period as they bed in and get a coating on the rotor
    Also ceramic have almost no brake dust ! clean alloys with a quick hose off no more scrubbing wheels
    Ceramic Brake Pads for clean wheels
  10. #30
    Dec 2008
    Sydney/Canberra
    Are those prices including GST?
    '01 Beetle 2.0
