Results 11 to 20 of 35
Thread: Rotor Sizes
    Apr 2010
    South Morang, Victoria
    I need to replace the front and rear rotors and pads on our 2009 T5 Caravelle after 75000kms.
    Has anyone had experience with the RDA brand?
    I found a set of front and rear rotors/pads for $192 and $222, respectively. Is this too cheap?
    Empowered Auto Parts Online Premium Brake Supplier
    I was going to get this job done by a mechanic who deals with VWs, but quotes start at $1100+, and having a look at a few videos I'm confident I can do it myself!
    Some of these mechanics said they use Textar and RDA.
    Recommendations would be greatly appreciated!
    Dec 2008
    Sydney/Canberra
    ATE are a direct replacement for the OEM parts, so same compunds used in the pads and rotors, etc, likewise Textar.
    RDA, etc you get what you pay for.
    $1100, or thereabouts, is pretty much what most T5s come in at, when I've priced them up for front and rear pad and rotor change, using decent parts. Seems like a lot, but once labour is factored in, it's at least a 2.5hr job to do properly.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Mt Cotton
    Unlike Umai I am NOT a mechanic but I have done multiple replacements to our 4 T5's over the years , its not that hard to do yourself . Probably the two bits that need a bit of elbo grease is cracking the two main bolts that hold the caliper to the hub , I used a jack under a long extension bar on each bolt and used the weight of the van to loosen the bolts while jacking the bar upwards . After that the only other ting is the backing off of the pistons , there is some info a couple of post a few weeks ago with that info . I used one of the Forum sponsors for the parts they are based in Brisbane GSL Rally Sports , you can give them your VIN number and they can then quote you a price for various brands and quality parts .
    Aug 2016
    NSW
    Don't forget the 10mm spline bit.
    2018 Crafter Runner
    T5.1 6sp manual.
    Mt Cotton
    Yes but you can get away with an allen key or a light tap with the tip of a screw driver for the one on the disc itself .
    Dec 2008
    Sydney/Canberra
    There's probably a hidden reason here as to why mechanics charge what they do...
    '01 Beetle 2.0
    Aug 2016
    NSW
    Quote Originally Posted by Umai Naa!! View Post
    Because they can?
    2018 Crafter Runner
    T5.1 6sp manual.
    Sydney NSW
    Well they have to earn a living, I get that, as a tradie myself, insurances overheads ect ect.
    For brakes the job is about as easy as it gets.
    2011 T5 4MOTION Duel Cab Optioned up.
    Dec 2008
    Sydney/Canberra
    I was more referring to the investment in the specific tools required to do the job properly.
    '01 Beetle 2.0
    Mt Cotton
    Sorry Umai I wasn,t trying to undermine the expertise and cost regarding tooling etc that you most certainly have .
