Results 31 to 35 of 35
Thread: Rotor Sizes
REVHE4D Rotor Sizes 02-03-2018, 06:42 PM
LogicprObe Normally you can put your... 02-03-2018, 08:08 PM
LogicprObe I'm guessing that you have... 02-03-2018, 08:16 PM
Sunny43.5 Up here in Qld I use GSL... 02-03-2018, 08:28 PM
Kachingg I would go for ate ceramic... 02-03-2018, 08:53 PM
Umai Naa!! Huge money for a Transporter... 02-03-2018, 09:29 PM
REVHE4D Thanks for all the responses ... 05-03-2018, 10:56 AM
REVHE4D Turns out the rotors are... 06-03-2018, 04:50 PM
Umai Naa!! My 1.5T has been so far... 06-03-2018, 05:19 PM
REVHE4D Thanks Umai Naa Sent from... 06-03-2018, 07:56 PM
Umai Naa!! ATE are a direct replacement... 27-03-2018, 08:40 PM
blaast You wouldn't recommend RDA? ... 06-04-2018, 12:59 PM
Sunny43.5 The discs if originals are... 06-04-2018, 03:28 PM
Umai Naa!! That means they're at least... 06-04-2018, 07:13 PM
Sunny43.5 Unlike Umai I am NOT a... 27-03-2018, 11:54 PM
LogicprObe Don't forget the 10mm spline... 30-03-2018, 08:11 PM
Sunny43.5 Yes but you can get away with... 31-03-2018, 01:19 PM
Umai Naa!! There's probably a hidden... 31-03-2018, 03:41 PM
LogicprObe Because they can? 31-03-2018, 07:03 PM
REVHE4D Well they have to earn a... 31-03-2018, 07:23 PM
Umai Naa!! I was more referring to the... 31-03-2018, 08:05 PM
Sunny43.5 Sorry Umai I wasn,t trying to... 31-03-2018, 09:25 PM
Kachingg Personally i would replace... 06-04-2018, 03:08 PM
LogicprObe I've got DBA solids on the... 06-04-2018, 08:25 PM
Transporter I didn’t have any problems... 06-04-2018, 08:40 PM
blaast Which of the following... 11-04-2018, 01:06 PM
blaast Just hoping I can get a few... 21-04-2018, 08:59 PM
Kachingg I have got ate ceramic pads... 21-04-2018, 09:14 PM
Umai Naa!! Are those prices including... 21-04-2018, 09:46 PM
Syncrotek My 2 cents I would replace... 21-04-2018, 11:15 PM
blaast Yes...! 23-04-2018, 07:35 AM
LogicprObe Those were the discs that... 25-04-2018, 08:32 PM
blaast The DBA slotted you mentioned... 26-04-2018, 09:12 PM
LogicprObe Yes. I was using their pads... 27-04-2018, 03:08 PM
blaast I need to replace the front... 27-03-2018, 08:20 PM
    Apr 2010
    South Morang, Victoria
    Quote Originally Posted by Umai Naa!! View Post
    Are those prices including GST?
    Yes...!
    Aug 2016
    NSW
    Those were the discs that warped on mine.............but they are probably OK if you aren't carrying heavy loads and driving down Bulli Pass or My Ousley every day.
    2018 Crafter Runner
    2012 T5.1 6sp manual.
    2024 Crafter Auto
    Apr 2010
    Quote Originally Posted by LogicprObe View Post
    The DBA slotted you mentioned in an earlier post?
    Aug 2016
    NSW
    Quote Originally Posted by blaast View Post
    Yes.
    I was using their pads as well.
    They diagnosed it as being caused by a wrongly embedded sensor wire but I think it was to much heavy braking.
    Anyway, that seller replaced them under warranty no problem.
    (well, I actually had ordered the DBA solid discs from them so I could get the warped ones off and paired them with the Italian pads I've used ever since.)
    I took a full refund for the drilled and slotted discs and pads.
    2018 Crafter Runner
    2024 Crafter Auto
    Apr 2010
    I need to replace the front and rear rotors and pads on our 2009 T5 Caravelle after 75000kms.
    Has anyone had experience with the RDA brand?
    I found a set of front and rear rotors/pads for $192 and $222, respectively. Is this too cheap?
    Empowered Auto Parts Online Premium Brake Supplier
    I was going to get this job done by a mechanic who deals with VWs, but quotes start at $1100+, and having a look at a few videos I'm confident I can do it myself!
    Some of these mechanics said they use Textar and RDA.
    Recommendations would be greatly appreciated!
