Results 1 to 10 of 12
Thread: Roller Door
    Sep 2016
    Gold Coast
    Roller Door
    Hi all , would anyone be able to help or know where to get one of these in oz: VOLKSWAGEN TRANSPORTER T5 SLIDING DOOR ROLLER GUIDE RIGHT BOTTOM HOOKE – AXI CAR PARTS
    I can find left side ones but not right.
    I haven’t called Vw genuine parts yet but bet it would be expensive.
    Thanks in advance
    Riche Roller Door
    It this it perhaps?
    for VW TRANSPORTER T5 Sliding Door Roller Hinge / Bottom Right | eBay
    Volkswagen T5 Door Roller Guide Door Holder 7H0843398 | eBay
    With VW part numbers, its usually only the very last section of the part number that varies between LHD and RHD parts.
    Sep 2016
    Gold Coast
    It this it perhaps?
    Thanks for reply. The first link to eBay is UK I have already asked weather he has the H version which has the hook to hold door when open. Unfortunately he said he doesn’t have. Second link from picture doesn’t look like it has hook. But does advertise all part numbers??? Was hoping to find one closer to oz though. Thanks again
    Riche Roller Door
    Feb 2009
    NSW
    This is all that's left of the bottom right roller. Door wouldn't close so I took the thing off. Good thing we're on holiday... Roller Door
    Sent from my SM-G960F using Tapatalk
    Sep 2016
    Gold Coast
    So this is how I fixed it Roller Door. $6.95 roller from Bunnings cut down old pin tapped out , locktite new screw on. Seems ok Roller Door.
    Feb 2009
    NSW
    Have you got the receipt with the sku? Going to have a go at this. I need my sliding door! Lol
    Sep 2016
    Gold Coast
    Quote Originally Posted by ozgti View Post
    Rolltrak 29mm Replacement Convex Bearing and Threaded Stud Axle Roller - Bunnings Australia
    You need too drill out the centre pin on this to take the size bolt/screw you are going to use.
    My plan was to just use the nut that came with this but there’s not enough room for it. So that’s why I cut old roller pin down then tapped out for a counter sunk bolt/screw. Hope that makes sense. Good luck. Roller DoorRoller DoorRoller Door
    Feb 2009
    NSW
    How did you get the roller off the new pin?
    Sep 2016
    Gold Coast
    Drilled it out , don’t remember what size . Depends on what size bolt/ screw your going to use. Or drill out the hole bolt , then make like a bushing sleeve that fits snug between your screw & the new bearing. If you use a counter sunk bolt you might not need a bushing/sleeve. ???
    Feb 2009
    NSW
    I meant to get the shank out of the new roller.
