Results 1 to 9 of 9
Thread: RNS510 Retrofit coding question
    Sunshine Coast
    I have just removed the RNS210 and installed the RNS510 (3T0 035 680B) with 9w7 bluetooth module (7P6 035 730K). Once installed it all works perfectly. Even the OPS worked perfectly and displayed a van in OPS displayed when in reverse.
    Although i have coding errors on the following modules:
    Gatway
    Navigation
    Telephone
    Sent from my SM-G935F using Tapatalk
    You'll need to add navigation to the canbus gateway installation list, along with telephone.
    Sunshine Coast
    You wouldn't happen to know the correct long coding?
    It's an installation list as opposed to coding.
    Not sure how obdeleven handles this.
    In vcds it's a simple matter of ticking options.
    Sunshine Coast
    Thanks Karmold, I worked it out. As you said it's was as simple as ticking the navigation and telephone boxes, once I worked out where it was. On my screen shot it was as simple as clicking the pen in the red circle.
    Sunshine Coast
    Due to the transporter only having a single antenna connection and the RNS 510 having dual I now have an error "aerial connection open circuit".
    Am I better of purchasing an adapter or installing a second antenna?
    Get a dual to single fakra antenna adapter
    Sunshine Coast
    Thanks
    Sunshine Coast
    Is it possible to add MFSW controls to a standard steering wheel?
    http://pages.ebay.com/link/?nav=item...d=282276531942
