Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Ride "quality" on unsealed roads
    May 2012
    EdenHillsSA
    Administrators: If this topic has been covered elsewhere then by all means please accept my apologies and deal with it as best you see fit.
    I recently did some distance on what I would call fair to reasonable dirt road.
    The vibration/noise/harshness was something horrendous.
    I'm hoping it can be alleviated (in whole preferably, 'though that might be expecting too much) when I eventually come to change tyres, which are currently the 235/55 R17 Dunlops.
    The placarded pressure is 44psi (front). Next time I go off bitumen on a similar road surface I'll be dropping the pressures, but one wonders how far can that go?
    Any comments please?
    Secondly: while I'm quite happy with the road noise on bitumen surfaces, there's a lot of "bump-thump" reaction when passing over manhole covers, train line crossings, etc. Again this would be reduced a little by lowering pressures but I don't want to ruin the tyre life by wearing out the outer edges prematurely.
    Maybe the 44psi recommended is too high? What do you folk out there use - what experience have you had over a longer mileage than I've done (17,000km only, so far...)
    Any tyres out there which are significantly smoother and quieter (particularly off-bitumen)?
    Thanks ...
    2011 T5 132kw 7spdDSG 4motion, '89 Citroen 2CV, 2006 Subaru Forester SG 5spd
    Aug 2008
    Drop them to 30psi and feel the difference. The tyres will not roll of the rims and the van will not tip over at first sign of a bend in the road. You will just get a smoother ride.
    Actually, best bet it to take a tyre gauge with you and experiment by dropping the pressure by 2psi per go and see how it improves the ride.
    2014 T5.1 Multivan Tuned by Pendle Performance Australia
    Nov 2007
    QLD
    I agree with 30-35psi on unsealed roads, but I had been using 45psi for normal use which gives a reasonable ride, but found that the outsides of the tread were wearing too much, so I am running 55psi front and 50psi rear on a trip I am doing with a medium sized load of equipment.
    I would also say that the ride of mine has improved gradually after it got to about 100,000km and the suspension has loosened up a bit. (run in).
    Brian
    Adelaide hills, SA
    Droping the tyre pressure does help but also consider the higher profile tyres like Good Year Cargo Vector, 215/60R17, they will go on my T5 in next month or so, replacing the Kumho Solus KH15 that didn't last 20,000km with the tyre rotation every 5,000km.
    Jul 2007
    I run 52 psi all round and don't have "ride issues". Noise is at passenger car standards and does not intrude. I am running 16" steel wheels.
    I tried 17" wheels but prefer 16" for ride quality.
    I do a fair bit of unsealed road driving but avoid heavy corrugations.
    May 2012
    EdenHillsSA
    Quote Originally Posted by MultiplexMan View Post
    *Ours is a 132kw motor which comes with the larger diameter brake discs at front: are you saying that 16's will fit ok in place of the 17's?
    *If you're running 52psi and don't have a ride issue then there's either something radically different with the suspension on your vehicle, or else with what you & I regard as a tolerable ride. But thanks anyway.
    *Transporter ... thanks for the heads up on the Khumos (what a bargain...NOT). I'll get back to you when you've got some idea of the Goodyears you're about to try.
    Adelaide hills, SA
    I doubt that 16" wheels will fit on yours.
    Jul 2007
    @Transporter - Correct 16" will not fit.
    @ greymad - sorry, my experience doesn't help you
    I drive a Kombi Beach. I think the suspension is different from normal as I have parked alongside a standard T5, a Multivan and a 4Motion. My Beach definitely sits higher - even with the bull bar fitted and a full load. I checked my vehicle build codes and it should have stock suspension but
    I spend a lot of time in Workmates and Defenders. I know what a rough ride is
    May 2012
    EdenHillsSA
    Yep - that's what I figured re the 16 vs 17 inch wheels...
    ...and after 23 years driving Landcruisers up in the Cooper/Eromanga Basins I too, have a good idea of what constitutes a rough ride(!)
    Thanks again for the feedback guys... looks like a kidney belt & noise cancelling headphones for the immediate time being.
    May 2010
    Kilmore, Vic
    Hi greymad, I'm on my fourth VW. Mark iv Golf, two T4 transporters and now a T5 Multivan
    They've all suffered from 'crash' suspension, compared to other makes
    That is, they 'crash' over sharp bumps, such as railway crossings
    You do get used to it, and in fact if I hadn't read this complaint from motoring writers on numerous VWs', might have thought the vehicle I had was faulty as well
    But perhaps might be worth getting your shockers checked
    Get a bit of air in them, or broken mount or any number of other things, they will bang and crash around much more
    M
