All I know is that they are bloody expensive to replace!
2018 Crafter Runner
T5.1 6sp manual.
Mine broke at the hinge point about 8 years ago so I made up a thin piece of alloy and used acouple of small screws to hold it in place , still working 8 years on !! I'll take a photo later and repost .
Avoid replacing at all costs because as mentioned it's expensive and time consuming. I replaced mine and found an overseas VW website with detailed instructions on removing and replacing. From memory it involved trim removal starting from the passenger footwell and airbag trim cover on passenger side as well and took a while and many unrepeatable words.
I'll try and find the OS VW forum link unless someone beats me to it.
Hey thanks all, links and photos would be greatly appreciated for when i build up the courage then fail at levering that metal shaft back into place
I should add the drink holder unit I bought from my dealer had the positive and earth wires in reverse to the unit originally in my van, so just check carefully as at first I thought the replacement unit was faulty and my cig. lighter and back-lighting didn't initially work.
I'd also suggest to carefully note how the wiring is routed in the underside of the tray, as it needs to be seated exactly as it was before removing to avoid fouling when you slide the tray shut...so I had a few dramas when replacing.
That a lot of steps to get to that parts, but it's all pretty straight forward unscrewing and removings bit so you should be fine if it comes to that.
