cutting out temporarily on corners
Hi Guys
Have a bit of bad luck with my 1997 LWB 2.5 Petrol t4 of late.
The recent issue is when I drive around corners the van cuts out for a second or 3 then kicks back in and runs fine.
We just got over a major issue with the serpentine belt slipping and the causes the timing belt to slip!!! That issue was resolved and a few weeks later now this is happening.
Any thought to the fault??
Fuel related? I replaced the fuel pump a few months back.
Any help or feedback would be welcome.
- You may not post replies
- You may not edit your posts
Forum Rules
