Results 1 to 10 of 13
Thread: Replacement Battery for 2012 T5.1
    Jul 2009
    The Gap, Queensland
    Looks like the original battery is in the way out in my van.
    What replacements have people been putting in these vans here in Aus?
    How is 5 years for the original these days? (I had 8 years from the original in an '82 T3.)
    Thanks folks.
    Sent from my SM-G900I using Tapatalk
    2012 132kw T5.1 TDI DSG 4Motion LWB Transporter, locking rear diff. Macron Campervan conversion. ECB bullbar. Milford towbar and rear light protector. Seikel Desert HD 30mm lift kit.
    Adelaide hills, SA
    After top grade Varta, the BOSCH S5 is a good choice. You can also fit a bigger battery there.
    T5 FAQ and How to THREAD (up to August 2009).
    Jul 2009
    The Gap, Queensland
    Thanks Transporter.
    (I put a compressor next to the battery so there is no room at all for a larger battery. Didn't even THINK of the possibility at the time. )
    Apr 2013
    Upper Gully VIC
    In 2013 I replaced my original 2010 battery with this on the advice of my auto elec - Platinum Power 2000 N55HMF 550CCA 100RC for $143
    No problems 3-1/2 years later
    __________________________________________________ __________________________
    VW Transporter T5 MY10 Van M 6spd 2.0DT 103kw White. Long wheel base. Standard roof?
    Adelaide hills, SA
    Quote Originally Posted by aSimpleLife View Post
    Hmm, bit on a smaller side. There is a reason why diesel vehicles have a battery with a higher CCA capacity.
    Apr 2013
    Upper Gully VIC
    Maybe I need to be looking for a new auto electrician as well
    Had hoped I didn't need to double check a paid professional.
    Haven't noticed any problems since then. What could the effects of this be?
    Feb 2015
    Cars like that need AGM batteries and buying one with higher CCA will ensure it will last longer. For your 2012 T5 these 2 are good, 730 and 760CCA. The higher spec one sells at the moment for $199 at SuperCheapAuto, but confirm again as well as the size too.
    MY15 TIGUAN 130TDI R-LINE - Pepper Grey, Panoramic Sunroof
    Apr 2013
    Upper Gully VIC
    Thanks for that.
    Jul 2009
    The Gap, Queensland
    Quote Originally Posted by dinot81 View Post
    Thanks. Was at Battery world a day or so back and they told me Century batteries are actually re badged Varta batteries. That should be a positive.
    On the other hand, with batteries, with every positive you always get a negative😂.
    Pacific Paradise QLD
    An optimist would say With every negative there must be a positive at the other end.
