Results 1 to 6 of 6
Thread: Removing Seat Belt - Multivan
    Dec 2008
    Sydney Australia
    Hi Vanners,
    Has anyone had any experience removing the a seat belt from the rear 3 person seat. ?
    Our dogs have decided they like the seat belt and have chewed though one.
    I plan on sending it away for repair.
    I have found a place in Perth that does Australian Standard seat belt repairs.
    thanks
    thebug
    The VW Bug
    2010 Golf 2.0 103kW TDI Manual White
    2011 Multivan 2.0 132kW TDI Sliver
    2018 Multivan 2.0 TDI White
    Aug 2008
    The lower section is just a simple bolt to undo, cant remember exactly how I did it. Half tilt the backrest back and lift the base up, should be able to slide a spanner in and get it undone. I did mine when fitting a seat to cover.
    As for the top mount with retractable mechanism.....I have not done. Unscrew the plastic guide in top of chair where the belt come out and have a look in there.
    Good luck!
    2014 T5.1 Multivan Tuned by Pendle Performance Australia
    Dec 2008
    Sydney Australia
    Quote Originally Posted by Ivo View Post
    Good luck!
    hi ivo
    i have the base bolt sorted, the mechanics seems to be in the middle of the seat, not sure if you can access it.
    The VW Bug
    Aug 2008
    Any luck with it?
    Dec 2008
    Sydney Australia
    Any luck with it?
    no need to get a triple spline drive to remove the child restraint anchor points i will pick up this week.
    The VW Bug
    Aug 2008
    I bought a set from a tool shop, about $50 maybe. You can also use them to tighten your armrests.
