Results 1 to 3 of 3
Thread: Removing rear coil springs on T5 dual cab
    Jul 2014
    New Town Tasmania
    Hi, does anyone know how to remove the rear coil springs on an 09 transporter dual cab? I tried yesterday, but my spring compressors are too weak(made for car springs). I am trying to fit coil air bags to help when loaded.
    Any replies appreciated.
    Attached Thumbnails Attached Thumbnails Removing rear coil springs on T5 dual cab-vw-ute-mackay-hobart-via-stanhope-1-copy-jpg
    Mt Cotton
    Not sure if they are the same as the van but I have done our two T5 vans with new coilovers and removing the old ones was a breeze . Jack up vehicle remove shock then use a second jack to lower the rear control arm it will swing down far enough to get the spring out with no compressors at all . In fact once the control arm is down it will nearly fall out on it's own .
    Dec 2008
    Sydney/Canberra
    Yep.
    Spring compressors are useless for something like this. As per above, take the weight off the shock with a jack, remove the bottom bolt, and lower the arm down a bit. The springs are only just captive at full drop as it is, so you shouldn't have to lower the arm too far to get it out.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
