Results 1 to 9 of 9
Thread: Removing front seats - air bag disconnection
    Mar 2014
    Greenbank,Qld
    About to remove the front seats in a T5 with the intent of installing swivels to both seats. Just checking if it is sufficient to remove fuses before breaking the electrical connections to the seats. My logic is that the airbags are electrically operated so pulling (and replacing fuses) is simply taking away the trigger to setting anything off.
    Iza
    Quote Originally Posted by Izabarack View Post
    Iza
    Disconnect the battery.
    gavin
    Jul 2011
    gavin
    May 2006
    Adelaide South Australia
    I was also told by a friend who worked on Porsches & Audis that after disconnecting they would touch/rub the battery leads together.
    Maybe there is a condenser or something in the system that needs discharging.
    Numerous Mk1 Golf diesels
    Mar 2014
    Greenbank,Qld
    Thanks guys. Only had the vehicle a couple of days and have a lot to learn.
    Iza
    Mt Cotton
    The sensors in the seats are their twofold one for seatbelt warning and second for telling the airbag a seat is being sat on , apparently the passengers airbag will not deploy if it does not sense a weight on the seat be warned it can go of if in an accident you have a heavy weight on the seat .Someone on this VW forum had theirs deploy because of a handbag on the seat tricked the sensor . As others suggested battery off and leave then the lights on as it will drain off any residual charge or even leave the ignition on after disconnecting will do the same . Also worth noting do not turn on the car or reconnect the battery until all connections are reconnected or it may trigger a fault warning .
    Mar 2014
    Greenbank,Qld
    Appreciate the advice guys. Can someone confirm that nothing gets lost when the battery gets disconnected? I'm pretty sure, from reading elsewhere, that the DSG needs to relearn some stuff but that only takes a few ks. I also believe the radio does NOT need to be initialised after a global power down. I'm sure a lot of this is in the owner's manual but it is not the most interesting book I have ever had to get through.
    Iza
    Jun 2012
    NSW
    does 'initialised' mean re-entering the radio security code ?, if that's different, check if you need
    to enter the code when re-connected.
    Mar 2014
    Greenbank,Qld
    Found the bit in the owner's manual re: disconnecting the battery. Pretty specific in procedure. No warnings about losing anything. I guess it is always a smart move to disconnect the battery before ****ing with any of the electrics.
    Iza
