I'd also be interested to know this,
did you get your oil tested? and what was your aluminium ppm
I recently posted this thread in the CFCA oil issue fb page: Do we have technicians in this group that can unambiguously say:
* The damage is caused by aluminium particles in the engine oil or by the aluminium particles in the charged air, or both ? ( engine will suffer further damage from a “damaged” egr. cooler even if the charged air is blocked off )
* Does aluminium particles (always) cause engine damage ?
* Is it abnormal to have (excessive) aluminium in engine oil, in any type of engine after a couple thousand miles ?
* How much aluminium in oil is excessive ?
* Does slightly thicker oil cause engine or turbo damage ?
* Should different oil spec be recommended considering the difference in average temperatures in a typical Australian summer compared to a typical European winter ?
* Do we know if the issue is driver dependant ? Only one owners can tell.
Thanks in advance.
2017 VW T6 3200KG GVM LWB 132kW 7 Speed DSG (Campervan Conversion)
