I think you will find they are the type that are two piece the part with the two splits down the sides actually clips through from one side of the body there would be a small flanging washer on that side . Then the two centre pieces seen in the pictures are normally either permanently attached to the bumper or are a removable clip type , you may find you can push out the centre part which will leave the clip still in the body , it looks like the pin part has broken off the bumper mount .
