Results 11 to 20 of 26
Thread: Recovery points by Volkstrek4x4
    Feb 2009
    NSW
    They're designed for towing. Not snatching. The force applied from the kinetic energy is huge. They can snap tow points on proper 4wds.
    Sent from my Pixel 2 using Tapatalk
    Mt Cotton
    Ok makes sense I had to ask .What about these there are some Aussie manufacturers who manufacture HightTensile bolts etc . Bare Co - High Tensile Towing Eye
    Aug 2016
    South Yarra
    Again they’re towing eyes Sunny. The Relium ones are rated to 8t and can be used in conjunction with a bridle and snatch strap to be ‘snatched’ out of trouble, should the need arise.
    You could probably be winched out using the standard towing eye but I much rather the Relium ones TBH.
    Adelaide hills, SA
    That pricing is simply ludicrous.
    Yeah, that’s my thoughts as well. Surely there is a cheaper solution. I’d be looking at local fabricators.
    Feb 2009
    NSW
    Reading what they are, one company seems to just find another tow eye and receptacle and bolt it to the other chassis rail... Seems a bit steep for that.
    Mt Cotton
    There are plenty of Aussie companies that make specific components same as those Relium ones some even rated to 12 Ton so I would imagine they would have something that would do the job .http://www.bpwtranspec.com.au/wp-con...s_brochure.pdf But I only posted this as I can,t see just one company in Germany making something that will work , can I ask is the point where the Relium ones bolt into strong enough for the loads expected ? I would imagine that sort of kinetic energy could rip out the threads or do some damage to the chassis itself . I watched a Landrover Discovery tear off its winch because it was rated to a certain number of KG but the mounts just tore out like tissue paper under load from the chassis .
    Jul 2016
    I believe the Relium unit needs a bit of extra fitting to increase the pulling capacity.
    I recall reading about these a year ago, but the price and the added fitting to increase the capacity put me off.
    I'll see if i can find the info i read.
    2017 VW T6 3200KG GVM LWB 132kW 7 Speed DSG (Campervan Conversion)
    Jul 2016
    Aug 2016
    South Yarra
    Yeah the Rellium ones don't just "screw" into the chassis, there's actually a bit of work involved in the install.
    As for an aussie made product, they would need to be engineered to be rated and if they don't exist for our vans here in Aus then the engineering expense will be passed on to us and new users per se.
    Aug 2016
    South Yarra
    So I’ve finally received a price.
    To buy 4 sets would be approx $731 per set each. This includes shipping of the 4 sets to me.
    There would then be an additional small shipping cost to get them to you here in Australia if you couldn’t pick them up from me.
    If you would like a set I would need full payment up front due to the overall cost of nearly $3000 and also take into any customs and duty charges if we can’t get a commercial invoice with a lower price stated on it.
    Let me know.
    Mark
    Last edited by Markee; 22-08-2019 at 04:55 PM. Reason: Removed answer to previous question already answered above.
