Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Rear wheel alignment why you should check .
    Mt Cotton
    Okay today I wake up to no electricity [power lines down ] then go to load the van for todays job and damn flat tyre and its raining . So I pump it up with onboard compressor as it had gone down slightly last week so I just thought it was a slow leak . Twenty minutes later its flat again , so pull off the wheel and fit the spare and this is what I found . Apparently according to the tyre guys the rear wheel was way out of alignment , probably due to the runaway incident late last year when it mounted the footpath on its downhill path of destruction . And yes it was like this all the way around the inside , out of sight as it seems .
    [ATTACH=CONFIG]17082
    Attached Thumbnails Attached Thumbnails Rear wheel alignment why you should check .-20150617_170958[1]-jpg
    Apr 2013
    Upper Gully VIC
    Hope you got out of that for not too many dollars. Was the other side the same? It surprised me when I put mine in for it's first replacement tyres and found I needed a rear alignment too.
    __________________________________________________ __________________________
    VW Transporter T5 MY10 Van M 6spd 2.0DT 103kw White. Long wheel base. Standard roof?
    Mar 2015
    Mill Park/VIC
    Full wheel alignments are around $50, don't stress too much
    Erskineville, NSW
    Quote Originally Posted by zillar32 View Post
    Depends who does it and what type of machine they use.
    The best two shops i know charge $100+.
    Apr 2013
    Upper Gully VIC
    I was charged somewhere from $75-$100 a couple of years back.
    After what I've spent on the front axle recently - wheel alignments are small change now
    I was trying to say that before having my T5 it had never occurred to me that you would nee a rear wheel alignment.
    But that picture certainly shows the consequences.
    Mt Cotton
    Two new tyres front and rear balance front and rear alignment rotate etc $460
    Aug 2013
    Esperance
    Surprised to found mine did the same, left rear.
    Was told not adjustable.
    Mt Cotton
    I use Keith 4 Wheels here in Brisbane they have looked after our vans for over 12 years so they know them pretty good , yes ours was the left rear as well and they can be adjusted .
    Aug 2013
    Esperance
    Long way from Esperance to Brisbane
    Bought my bus in Brisbane
    What model do you have
    Mt Cotton
    The van in question is the 2005 t5 2.0 petrol manual .
