Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Rear Brakes T5.
    Adelaide hills, SA
    Quote Originally Posted by jets View Post
    Have you ever washed the van when the brakes are hot & squirted cold water at the wheels? I know solid discs can warp,I don't know what happens to ventilated rotors.
    No, always - cold preferably before I drive of - I wash my van at home; it was never washed at the servo.
    What amaze me that I'm not hard on the brakes, 65,000km, and 2mm of friction material remaining.
    Adelaide hills, SA
    Certainly, I have.
    Got discs on Monday and should change them on Saturday. ATE discs and ATE pads. Could also get slotted discs for $300 a set and $400 for front.
    Aug 2008
    My brake light and buzzer has come on so I guess I need new pads at a minimum. How hard a job is it to replace the pads? Any trick to retracting the pistons? Whats the minimum thickness for rotors? Van has 107000 kms on it.
    2014 T5.1 Multivan Tuned by Pendle Performance Australia
    Adelaide hills, SA
    Very easy, piston just screws in. I did another 20,000km after the warning came on, just cut the wires from the sensor at the right inner pad and joined two wires together - warning is "off" easier than with VCDS and saves you time to reactivate alarm when new pads are fitted.
    DBA Rotors no.
    Front DBA 2248 , SLOTED 42448 Min Th. is 25.5mm
    Rear DBA 2247 Min Th. is 19.5mm
    Brake pads min th. is 2mm front and rear
    Aug 2008
    Thanks mate!
    May 2013
    Not far from Cooma
    I've got to do the rear pads on my T6, which way does the piston wind in please, clockwise or anti?
    Dec 2008
    Sydney/Canberra
    Clockwise.
    You'll need a tool that pushes the piston as well as turns it.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Mt Cotton
    Yes there are special tools but if your a handy man you can make your own . I used a large socket the same diameter as the piston and then ground out a bit on each side to match the lugs on the piston , has worked for me for years now .
