Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Rear brake piston
    Sydney NSW
    My piston winder from supercheap broke, it was if poor quality and they dont make them to last, I ended up using a G clamp worked like a charm. I did both front and rear brakes and rotors, but undid the bleeder nipple to push the piston back, hence why I bled the brakes.
    Sent from my SM-G955F using Tapatalk
    2011 T5 4MOTION Duel Cab Optioned up.
    May 2006
    Adelaide South Australia
    [QUOTE=Umai Naa!!;1259386]I'd buy a full kit, but the likelihood of using everything in it, is pretty slim. Plus it's more to drag around everywhere.[QUOTE]
    I agree. Each kit I buy uses valuable shelf space in my storage cupboards. However I probably need different tools for each of my cars.
    Numerous Mk1 Golf diesels
    May 2006
    Quote Originally Posted by Umai Naa!! View Post
    With the premature rear brake wear on the MK5s, there was an issue on the early ones where the suspension movement would pull tension on the handbrake cables, causing a small amount of drag.
    In my case it was only on the LHS Caliper. Thanks for your comment anyway.
