Results 1 to 10 of 16
Thread: Prevoiusly telstra T4
    Feb 2009
    Newcastle NSW
    My newly acuired T4 was previously a telstra van (grab handles on the tailgate plus rta told me)
    Anyway how could I find out what they do to there vehicles?
    It has a black box in the whell step that says soldering and water pump. It has heavy duty cigarette lighter plugs (cant think of the name) but there is a 15amp one and a 40 amp one plus and anderson plug. Also running to just underneath it is two (I think) water lines that are blocked off.
    Just wanting to find out what it all is and how it works so I can use it.
    Yeah I know I could ring telstra but not sure how much sense I,ll get out of the phone operators.
    Nik
    Adelaide hills, SA
    The water lines could be hoses from the heater to warm up water in their sink (for washig the hands), used to be on the right when you open the sliding door.
    Boronia VIC
    The Black box is a battery power outlet.
    Linesmen would use the small socket for low powered devices like soldering irons and for charging gas detectors.
    The Anderson connector would typically be used for pit pumps or 12 -240v inverters for test gear.
    The water lines are for the heat exchanger in the hand wash station which would provide hot water for hand washing. Not the luxury you might think it is, some of the grease in the cables is a bugger to get off your hands without hot water.
    Other things you might find.
    Daytime running lights.
    Rear step.
    Tow points under car may have been removed.
    Roof racks and perhaps wiring for a work lamp on the roof.
    Gas safe or holes from it's removal.
    Some of the vans got LSDs
    I used to drive them once upon a time.
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Feb 2009
    Newcastle NSW
    Wow thanks for the quick very descriptive replies!
    It does have some big holes through the floor and ugly roof racks (which leak, so Im taking off. Do they sell more stylish low profile ones?)
    So did the hot water have a heat exchanger through the radiator pipes, how does it get pumped around? Or is it just and extension of the engine cooling lines using the engine water pump?
    Would I be able to find wiring/water diagrams so I can get it running again (or atleast make sure its safe) would be nice to keep and use.
    Mine is a syncro not sure bout the lsd tho.
    At some stage its been a motorbike van, lowered carpeted with tie downs, 17" wheels (comiong off as soon as I get an adapter for wheel nuts) two silly cannon exhuasts one out each side!
    And supposedly 63000km on a 96 model??
    Nik
    Boronia VIC
    Here's one on ebay.
    http://cgi.ebay.com.au/Ex-Telstra-Va...22208001r17451
    The blue bowl folds down to wash your hands. When you fold it back up the water gets tipped out through a drain in the floor.
    They are filled with fresh water through the blue cap on the top and there's a sight gauge to see how much water is in it.
    Plumbing only required they don't use any power to work.
    There's a small 'heater core' inside the box which heats the fresh water while the van is driving around. It's just plumbed up the same as the van's heater core and the engine pushes the water around.
    It's not a great camping solution though, if that's what you're thinking, the water's only hot after the van's been driving around. First thing in the morning it's all cold.
    The heaters pop up on e-bay all the time, keep an eye out.
    Pete
    7? MK1 Caddy
    12 Amarok
    Boronia VIC
    7? MK1 Caddy
    12 Amarok
    Feb 2009
    Newcastle NSW
    Was thinking of using the lines to run a hot water unit for showers (cant think of the name but sealed unit with wound copper pipe) and Id really like to use the power outlet.Maybe just rewire to run thru 2nd battery?
    And the sink explains the LARGE hole in the rear left corner!
    Nik
    Boronia VIC
    Power unit might still be wired. There should be a big red isolation key in the box to turn it on.
    Pete
    7? MK1 Caddy
    12 Amarok
    Jan 2008
    Mallacoota, Vic.
    Quote Originally Posted by vannin View Post
    I had an ex Telstra T3 syncro, before my current Trakkadu. I used the hot water lines to make my own hot water service, which worked extremely well. I just made a tank from 2 lengths (about a metre, and in retrospect, I think one would have been enough, and much simpler) of 150mm brass pipe (from a building wrecker). The tank needs to be able to withstand the pressure of the heating water, which can potentially get to boiling point, so needs to be stronger than just a fabricated sheetmetal tank. A pressure relief valve is also a good idea. I fitted a single loop of copper pipe within this (make sure you support it at both ends), connected to the hot water lines. The water seemed to circulate fine on its own. Then you need an inlet (low) and outlet (high) pipe for the fresh water supply, pumped from your main tank. I used a pump with a pressure switch, so when you opened a tap (hot or cold) the pump would trigger and the water flow, just like at home. If you insulate the tank you'll probably find it is still at least luke-warm after an overnight stop, and it heats up quite quickly when you are running. Be aware that your coolant temp might run up to 110 degrees, so the hot water is sometimes scalding hot.
    This set up had the advantage of providing about 20 litres of hot water, without having to run the engine, unlike my current system which has no reservoir, so you need to run the engine to get more than about a cupful of hot water.
    And I also used the 12 volt outlet wiring for my 2nd battery. Nice heavy wiring.
    Brian
    Feb 2009
    Newcastle NSW
    No that I think of it the extra plug is probly the on/off key!!
    Yes thats similar to what I was thinking for the hot water Id rather use it the take it all out. Do you have a pic of your set up?
    Cant do a great deal yet waiting to get the r&r bed fitted 1st.
    Nik
