Hi Guys,
My powersteering fluid is slightly low (just below Min). I will obviously need to top it up. Is it normal to top up after 4 years (57,000 Ks)? No signs of any leaks, fluid is reasonably clear - although a tiny bit of sediment in the reservoir (presumably 'normal wear' coming from hoses and seal material). 2008 TDI Multivan.
Or is this something to investigate further with the Powersteering pump seals?
Cheers,
Scott
