Talk to Trakka about your concerns. They should be able to reassure you one way or the other.
As for your side note....don't forget to get the reinforced version of a 205/70R15 (the one with the C on the end) so you maintain the load rating. As a long time T4 dirt tracker....I can recommend the GT Radial Maxway in this size
http://www.tyres4u.com.au/t4utyresel...9763_show.aspx
Oh...and if yours is a syncro...don't forget the rear diff spacers with the lift...they are needed to reduce risk of rear driveline and CV wear as a result of the lift.
