Dear M.,
Here's a query for a VW expert and mechanical engineering student.
I'm tempted to buy a VW Caravelle with the more powerful diesel and 4WD. It would be good for camping expeditions.
But the ground clearance is poor (165mm) and made worse, in practice, by the wide track and long wheelbase.
The aim is to get up and down bush tracks in national parks, nothing too serious. Over the last few days we have been to Kaputar and the Warrumbungles and around Lightning Ridge. Some of the tracks had sunk wheel tracks and a highish middle of the road.
Trakka who make impossibly expensive conversions offer some modifications by the German outfit Auto Seikel. Their most elaborate offering improves the ground clearance with suspension modifications, adds bigger wheels, and changes the gears to provide lower lower gears. The full deal is a bit over the top.
However the simplest modification simply seems to provide longer coils and shock absorbers to gain 30mm. I guess the kit could be bought by mail order.
You can see the offerings on the Auto Seikel website and hitting Configurator and then "T5".
Cars with independent suspension have constant velocity joints at the inboard and outboard end of the drive shafts. And CV joints with necessarily greater ability for large angles for the steering wheels.
Now I'm wondering whether standard CV joints could handle the more extreme angles if you put in longer springs. Or is the downside that they might fail rather quickly and/or cause vibration.
And, of course, the suspension arms would have different angles and there might be problems with this.
Any ideas about these issues or about who we could ask?
The more obvious and simpler downside is multi-story carparks. Solution, a hacksaw and the first Caravelle convertible.
Thanks for any thoughts you may have.
Graeme
PS don't be distracted by their lift kits for Golfs!
