Pioneer 5250BT in T5 Caravelle...
Thought I would post this query in the 'van lovin' central' forum because I don't think I would get much 'van lovin' feedback in the audio section.
I'm very interested in the Pioneer 5250BT because the screen can be adjusted +/- to suit, especially with the angled dash on the T5.
I should be able to get it for $770, plus a reverse camera for it.
Should this be an easy install since it is just a single DIN unit?
I am guessing I won't need a facia, but I will need something to fill in the DIN sized hole left...probably a tray if one is available.
While I'm here, what size are the speakers in the front and rear?
Cheers!
Hi,
I just purchased an Alpine IVA-D511 (single DIN) to replace my IVA-W202E (double DIN) for exactly the same reason. It is an easy install.
Your van should have come with a "cubby pocket" for the empty slot - unless it was supplied with a double DIN unit from the factory (?).
Cheers, MM
That's a great price compared to the official rrp.
- You may not post replies
- You may not edit your posts
Forum Rules
