Originally Posted by
Silver Caravelle
Thinking about this further. If it is running perfectly fine the rest of the time, it sounds like a loose electrical connection. Things to check. Earth leads from engine to vehicle body (unlikely), Knock sensors connections on the front lower section of engine block. Check O2 sensor connection (down stream from the exhaust down pipe). Blocked Catalytic converted intermittantly, Fuel pump connections, coil connections and HT lead?
Does the engine stall like the ignition is turned off or just struggle for power?
Cheers,
Scott
