Results 1 to 4 of 4
Thread: Opinions: Disconnecting batteries when away from the van (1month+)
    Oct 2014
    Hi all,
    About to head on holiday (not in the van) for around a month - have seen some mixed opinions online in my research about disconnecting both the starter and 2nd battery while i'm gone.
    Does anyone have experience or opinions on disconnecting the 2nd battery (lithium) while i'm away? No power will be drawn (not running anything) while i'm gone - is it worth it?
    I'd imagine the newer batteries are capable of dealing with this length of time?
    Any opinions appreciated.
    Apr 2014
    Chelmer, Queensland
    You do have the code for the sound equipment?
    The battery should last for a month ok assuming its in decent condition to begin with.
    The other alternative is to buy a smart charger and leave that connected while you are away. Ctek and Noco make good ones (ive got a Ctek).
    Jan 2008
    Sunshine Coast
    I have a drain on my starter battery, so I disconnect it all the time without issue. Need to sort it, it's quite annoying.
    The Lithium will be fine sitting there charged, so I'd disconnect it too just to be safe.
    If you don't have drain on the batteries, then no need to disconnect at all!
