Results 1 to 6 of 6
Thread: Opening rear tail gate from inside on a T5
    Sep 2014
    Capalaba, QLD
    Has anyone modified their T5 so they can open the tail gate from inside, I was hoping to see some pictures to get some ideas!
    Thank Sim
    Sep 2010
    ACT
    There is already a way to open the tail gate from inside: first, take off the small round cap from the back side of the tail gate. It will reveal a hole. There is a lever inside the hole that you can press to open the tailgate from inside.
    If you plan to do this often, attach a string to the the small round cap so it wou dbe easier to remove it next time.
    Multivan MY12 TSI350 Red. Previous: 2008 Tiguan 103Tdi. 2010 Tiguan 125TSi.
    Sep 2014
    Capalaba, QLD
    Yes I'm aware of that, I was hoping for a permanent solution as I have a draw system and cannot reach down from inside easily
    Dec 2008
    Sydney/Canberra
    Run some Bowden cable from the lever to somewhere higher up?
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Feb 2009
    NSW
    Quote Originally Posted by Umai Naa!! View Post
    Get a shaved door popper and wire it up. Then stick the popper remote somewhere up high.
    Sent from my SM-G930F using Tapatalk
    Dec 2016
    I also have drawers with a bed on top and like to open the tail gate from inside.
    I used a bit of curtain wire attached to the manual mechanism which runs up to a small hole I drilled next to the brake light.
    Works good just pulling on the wire although the plan for the finishing touch is to find a cool figurine to stick on top.
    Sent from my E5823 using Tapatalk
