Yes, it looks like a bit of the oil leak. Clean it and see if it re-appears.
Hi All,
Interested if anyone can advise what these bits are, they look like sensors to me, but I am not sure.
It looks like there is oil leaking from through or around the top one if that is possible?
I could not see any oil above this part, not enough to be literally dripping off the wire as you can just see about to happen.
Thanks
Michael
Although it is a little hard with the coolant pipes running this way and that, I can't see any oil above this point in any amount that would cause it to drip as it does. After the car is off depending on the surface creates a nice little pool of oil.
What are these parts to replace?
Are you heading up north any time soon Transporter?
Oil pressure sensors by the looks of them. Give it a wash and recheck to save you from replacing the wrong one.
Sent from my HTC_PN071 using Tapatalk
Volks Handy
Servicing - Repairs - Diagnostics - Mobile fault scanning/clearing - A/c work
10 years experience working for Audi/VW/Skoda
Now in Perth NOR, Western Australia.
Bummer, now the power steering is playing up.
Can you suggest what to check for the symptoms of losing fluid and a smokey smell?
Michael
