Results 1 to 7 of 7
Thread: T4 pwr steering oil
    Aug 2011
    brisbane
    T4 pwr steering oil
    is there a specific type of oil to use, and does anyone know roughly how much is needed for a full replacement?
    Dec 2008
    Sydney/Canberra
    Needs to be G002000-spec.
    Do not put ATF in it.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Adelaide hills, SA
    Quote Originally Posted by ericcs View Post
    Around 1L needed. You can get Penrite LDAS or LHM Plus oil, check number on P/S reservoir for which to use.
    May 2006
    Adelaide South Australia
    Quote Originally Posted by Umai Naa!! View Post
    The early T4s used a different oil to the later ones. My '01 has a green lid whereas the early lids were a shade of red [from memory].
    The oil I bought for mine is G 004 000 M2 & I just noticed "useable until see above" The date has disappeared but obviously has a limited life.
    I wouldn't bother trying to find a cheaper oil than genuine, from memory it wasn't too expensive.
    Numerous Mk1 Golf diesels
    Adelaide hills, SA
    Quote Originally Posted by jets View Post
    The oil spec is usually on the reservoir.
    Dec 2008
    Sydney/Canberra
    Genuine is about $25 for the litre bottle.
    From memory, G004000 (green) supercedes G002000 (yellow) that was used in the earlier models.
    '01 Beetle 2.0
    Aug 2011
    brisbane
    ok, thanks for the replies. the car has a green cap(96) on the reservoir, but i have just installed a second hand rack, which could be from any year. So do i take the punt and just stick with the green grade oil?
