Results 1 to 5 of 5
Thread: OBD2 Reader
    May 2017
    Vic & Tas
    OBD2 Reader
    Over the last 6 months I've had 2 dash warning lights come on intermittently, so I thought I'd buy myself an OBD2 reader to try and see what's going on. Spent nearly $200 on a Foxwell NT301, connected it up this morning but no diagnostic codes were detected. Is it me not using the device correctly or is it VW keeping things secret?
    2017 T6 2lt Diesel Manual
    The only person to get everything done by Friday.......was Robinson Crusoe.
    If the warning light has come on intermittently then it may not have stored an error code. If the warning light stays on permanently then it will store an error code which you can then retrieve with a scan tool and it will give you an idea of what the car is not happy about.
    The Foxwell device you have purchased should be able to do the job, but for a similar price there are VW specific scanners available which I would recommend.
    Pacific Paradise QLD
    Mt Cotton
    Whilst those scanners give info I doubt they have the ability do any changes that maybe required , I bought a Launch X431V which uses Bluetooth for communication via the OBD port plus multi cables for other makes etc . Allows long coding and has been real good for our two Transporters to change factory settings . 2024 LAUNCH X431 V + PRO5 Elite Bidirectional Car Diagnostic Scanner ECU Coding | eBay
    Aug 2016
    NSW
    I use VCDS for my VWs.
    I got a Foxwell for the Missuses Benz and found it fairly clunky to use by comparison.
    2018 Crafter Runner
    2012 T5.1 6sp manual.
    2024 Crafter Auto
