Results 1 to 4 of 4
Thread: OBD2 bluetooth?
    Aug 2017
    Holsworthy, NSW
    OBD2 bluetooth?
    Hi All,
    Wondering what are good options for watching some diagnostics as I drive my T5.1? Particularly interested to see when it does any regen and to see any fault codes on the fly. Is it as simple as a cheap ebay OBD2 bluetooth dongle and an android app, or are there better options?
    Thanks, Sam
    Carista - hands down. You can see soot levels and initiate a regen at your convenience with Carista - I use it regularly on my 2015 Audi SQ5 as it seems to always want to do a regen at an inconvenient time (eg when you are 5 mins away from home after a 2 hour trip on the freeway). So now I can initiate a regen at a convenient time for me. Carista OBD2 Diagnostic Scanner and Customiser for Android and iOS – AutoInstruct
    Carista is $46 to buy, and then full access to the apps features is approx $80 AUD per year.
    You can also use the Carista OBD device with another app called VAGDPF which gives you a heap of DPF pressure/temp parameters. The only downside to VAGDPF is that you cannot initiate a regen. VAG DPF app on Android to monitor DPF
    Jan 2008
    Sunshine Coast
    Great info, I used to run VAG DPF all the time, some great info there, and just push a regen via Ross Tech as suited me.
    Good to no longer have to worry about all that ****, and the insane underbonnet temps regens cause.
    Mar 2022
    Hervey Bay QLD
    So for a technologically challenged (dumbass) like me that only wants to be able to read and reset fault codes on my 2012 T5 TDI do you just plug the Carista adapter in and connect it to your phone and use the free OBD2 diagnostics that comes with it?
    Also is their a cheap stand alone scanner you can recommend that would do the same thing on the T5 and easier to use?
