Obdeleven.com. buy one for $139 from AutoInstruct – The Home of Automotive Guides and Products and read the VCDS section forum all about what you can do with it an android phone
It may not have full functions on a Transporter though
I'm interested in peeking at my 2007 build (2008 spec) 2.5 TDI Multivan.
Can anybody recommend a scanner? Bosch told me yesterday that their OBD 1110 model can't be used on the multivan, even though it's listed as a Transporter compatible device.
I bought this VAG COM 17.1.3 HEX+CAN USB Interface Car Auto Fault Diagnosis Wire Diagnostic AG | eBay from ebay. I'm happy with it. Only downside is I need to use a windows laptop. I have a 2007 VW T5 Transporter 128kw AXE Auto.
Thanks guys.
I'm getting the feeling that a scanner isn't warranted on a Multivan.
It depends what do you want to use it for.
The OBD eleven is a very good alternative to VCDS.
If you only want to read the codes and perhaps monitor the DPF as well, I found this one is very good for that. Just use VAG DPF app and for the codes Dash command app.
Foxwell OBD2 Bluetooth Car Code Reader ELM327 V1.5 Adapter Auto Scanner Tool 655421695740 | eBay
It is true the OBDeleven isn't as great with the Transporter as it is with other VAG models. I spent a week to-ing & fro-ing with Voltas (the company that developed it) to help with deactivating stop-start function to no avail. I have had more success with a couple of the other functions though, along with reading & clearing a couple of fault codes.
