Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: New tyres....
  1. #21
    Pacific Paradise QLD
    Quote Originally Posted by Tig-uan View Post
    I thought that it is illegal to install tyre size that changes the wheel radius by more than 7mm? (not that I care, just trying to ascertain if I am understanding the rules correctly).
    No you arent the rules state you may not increase or decrease the DIAMETER by certain amounts
  2. #22
    Quote Originally Posted by heyasam View Post
    Hey @Tig-uan for example 75mm Lifts Now Legal In NSW | Loaded 4X4 makes reference to the rules. Sorry haven't looked closely for a while. Maybe I got my math wrong and 235/65/17 + a 2 inch lift would be ok
    Not sure if its still the same but used to be a larger tyre OR a lift but not both Happy to be corrected
  3. #23
    Jun 2011
    That link says both are possible but must not exceed 75mm total lift ie:
    50mm suspension lift plus 25mm tyre lift
    Or
    25mm suspension lift plus 50mm tyre lift
    Can’t both be 50mm
  4. #24
    Aug 2017
    Holsworthy, NSW
    I think this is the important bit :
    Modifications to the ride height up to 75mm that incorporate a maximum change in the suspension of 50mm, and/or an increase in the diameter of the wheel and tyre combination of up to 50mm
    From here
    https://www.google.com/url?q=https:/...5RrXzJ7eknnVTS
    Can someone confirm the standard raised king springs are 2 inch / 50mm?
    Then the king springs, which another thread suggests work with factory shocks, as well as 235 65 17, which fit deflated in the spare wheel well, seems the cheapest legal path to go down, or up per se, and is what I've been planning to do. Maybe air suspension one day would be nice though if I can justify the cost.
  5. #25
    Oct 2021
    Newee Creek, NSW
    Curious to know how these tyres are going.
    I'm trying to find a better wearing tyre that the Yoyo that have given my less than 15000km.
    Would appreciate your advice.
    cheers
    Kendall
  6. #26
    Feb 2009
    Torquay
    I reckon the best way to go is to increase tyre size to 60 profile, rather than the much larger 65 profile - ie 235/60/17
    • fits in spare well inflated
    • speedo is pretty much bang on accurate (over-reads just slightly).
    Am currently running cooper AT’s in this size and they should last long time (especially compared to the Yokohama’s that I was using).
