No I wouldn't describe it as being limp mode I have experienced that in my wifes old T5 2.5 Turbo diesel , mine drives fairly normally just takes a bit of peddling to get it up to speed from stop . It does accelerate but not at a rate that would keep it up with other traffic from lights etc . No sign of smoke , oil consumption around 1 litre every 3 to 4 thousand kays [that's if I remember to check it ] LOL and from what I have read on some posts that's way better than some brand new model VWs which seem to have a high oil consumption rate from factory . We were warned to keep an eye on our new T5.1 oil level when we picked it new from dealer , they even told us with great glee that they had a "Pit Stop" set up at the service dept so if the oil was low you could just pull in and they would top it up WTF !! I will make a booking with Jmac and see what turns up , I do know the joint between the first section of down pipe in the exhaust is fractured so a trip to an exhaust shop is in order , I wonder if that may be affecting the O2 sensor which is just down a bit further from memory . it makes a sort of whistling sound on acceleration . I wished I had put a turbo on the van when I discovered ten years ago that it was no where near the performer of the T4,s 2.5 petrol which was in my old work van back then , that engine was a real goer a certain hill near home has a small sort of lump part way up and it would lift the front pass side wheel off the ground and chirp the tyre this one just rolls over with very little enthusiasm Sob sob .
