Results 1 to 10 of 17
Thread: Need Advice Please .. Re T5
    Mar 2008
    Sydney NSW AUSTRALIA
    Its Noddy again folks... I'm in need of your help. Thanks everyone on your response to my other post.
    Continuing the saga re noise problem in gearbox (maybe ) of new LWB 128kw Auto Transporter. Today I met with Volkswagen Australia rep who after driving the vehicle believes the issue "maybe " TURBO related. So this vehicle with less than 2000ks on the clock is about to undergo a turbo replacement.
    I have a couple of questions I would like your advice on please.
    The 1st is .... ( and I am completely a non mechanical person - that is why I bought the Volkswagen - believing I would get years of trouble free motoring )
    ... As I don't know the extent of the turbo problem ...only that ..if it is the turbo.. it has been making a loud rubbing type noise and causing the auto transmission to behave badly...jerking between 1st and 2nd gear and causing noise in other gears..at about the 2000 to 2500 rev mark...The question is..
    ...Would driving the vehicle todate ..ie 2000ks with a crook turbo ...have caused me other problems ...ie. engine issues...could I expect problems down the track because og the crook turbo.
    The second question is related to the roof lining...when I picked up the vehicle I noticed the lining had a bow in it.... it got replaced the other day and blow me down if the new lining ended up with a bow in exactly the same place...( bowing occurs when the lining is attacheh to the roof )..can't just be a co-incidence can it ? Has anyone had any experience with this.Volkswagen are trying to get to the bottom of this one as well.
    Other items such as dash rattles, noise in the steering, headlights out of alignment,and missing trim piece appear to be rectified or are in the process of rectification.Paint damage noted at time of delivery is still under resolution.
    Sadly what should have been a great experience for me in buying a new Volkswagen is turning into a misery and I am slowly developing poor vibes about the Volkswagen product ...not the folks from Volkswagen endeavouring to assist me...they have been great..just the product.
    Please folks ....if you could answer my questions I would be very appreciative.
    thanks in advance
    Noddy
    Camden, Sydney
    Its usually complaints about the staff and praises for the product mate.
    Update your location details in your Control Panel.
    Which piece of the lining is sagging?
    Mar 2008
    Hi, im in Sydney
    the lining is hard masonite and the bow is on passenger side rear cargo area LWB T5
    thanks
    Jan 2007
    South Australia
    Hate to say this Noddy.......
    The T5 sounds like a lemon
    My advice if everything is fixed at no cost to you under warranty and you have no probs after, then extend your warranty for an extra 2 years if nothing happens then keep it.
    Otherwise look at a used one maybe ??
    I'm not the most knowledgeable mechanical person just plain common sense is my thinking.
    - Ben
    1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
    2008 Jetta 2.0L FSI
    Canberra
    From what I've read on the Brickyard there are way too many T5s with various problems. Some people don't have any issues, but you tend not to hear from them. The T5 just doesn't seem a reliable as the previous van (T4)
    But almost everyone agrees that when they are running right the T5s are great to drive
    I don't think a turbo problem would cause jerky gear changes and noises in the gearbox, or at least I can't think of a way that it would. Most turbo problems I've heard of (apart from total physical destruction) seem to cause a distinct lack of power (either all the time, or suddenly above approx 2,000rpm).
    I haven't noticed any bowing in the rear roof lining of my van. Is it possible your van was built with an attachment point in the wrong place (slightly misaligned, thus causing the bowing) ?
    Mar 2008
    Thanks lads for your replies......Definitely feeling like it is a lemon. My discussions with Volkswagen earlier today centred around replacing the vehicle with another .... at no cost to me... could be a chance ...but a few more rounds of discussion need to take place.
    If noise problem is still there after turbo change then there may be a chance....if noise gone after turbo replacement ...then no chance of replacement....that is why I am asking the question about possible damage done to motor whilst crook turbo still in vehicle.
    I take the point about attachment point in wrong place in roof possibly causing bowing....I actually raised it myself with them....just have to see how they rectify the situation.
    If I do end up keeping the vehicle I'm sure I will be wondering ...What next ?.
    If anyone else out there can shed some light on my turbo and roof questions I would be very grateful.
    many thanks
    Noddy
    Jul 2007
    Many Peaks Queensland
    Get everything in writing that is wrong and maybe even tape the conversation if in your place your legally aloud.
    Taking on a car company after the fact is very difficult and car companies have a policy of no fix if you don't mention it. IN other words if they think they can get away with a problem until the warranty expires they will.
    The mechanics are told not to tell you about issues that are not at that time safety related, even though in 50000 ks or whatever they may be.
    You should keep a tally of all your time and quote a rate of about $100.00 per hour, which is what they tend to quote, so that when they try and get you to keep the lemon you have something up your sleeve for later on.
    Ask them once thye have supposedly fixed the problems. Will you give me a new car in its place if the problems come back or other ones related to these issues arise and see what their response is. Naturally enough if they say no then you can bet your bottom they expect their to be more problems.
    buy a toyota hiace
    Aug 2007
    Forrestfield Western Australia
    Noddy,
    One out in left field but have a look anyway and see if this is contributing to your noise problem.
    My T5 Multivan 128kw just started making a strange noise and I was wondering if there was a turbo or transmission problem causing it. I had a look under the bonnet and noticed that one of the plastic screws that fix the plastic lining to the front of the car was loose. These are the screws you see on top of the front member running across the front of the engine bay above the radiators etc and look pretty harmless. I tightened them all up with a ten cent piece and wonder of wonders, no more noise. It seems that the plastic vibrates at about 2000 to 2500rpm and sounds about as loud as the normal engine noise added on top of the normal noise. Quite strange, but easily fixed.
    The six speed auto on mine also does strange things at times, as other people have reported. After coasting down hill or slowing down, when you accelerate for the next hill it changes down a couple of gears and revs the engine for a bit, before going back to normal. Quite strange but seems harmless.
    Bob
    Ex 2004 Transporter TDI T4
    2007 Multivan Comfortline T5 128kw TDI Auto
    Mar 2008
    Thanks for your thoughts....I check it out...they still haven't got a turbo to replace the other one yet. This is becoming ridiculous.
    Ive been googling info about turbos trying to understand some of the probs associated with present problem. Found a site where the article describes a "whizzing" sound in turbos as a problem...I get this sound along with the clunking sound I have described.....will be interesting to see how it all operates once I get the new one in.
    I'm definitely pursuing replacement vehicle and will dog this issue to the end. Have a very supportive salseman on side and now regional manager involved and expressing empathy...need this to become reality and I may get good result.
    In the meantime I continue to be without a vehicle and the compensation claim grows...Volkswagen have a least indicated they will compensate me if replacement vehicle doesn't happen.
    Please keep thinking about possible reasons for my noise problem.
    I am very appreciative of everones help todate.
    kindest regards
    Noddy
