Page 7 of 10 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 93
Thread: Mystery noise from under the hood
  1. #61
    Jan 2016
    yimbun qld
    I have 2011 multivan is losing coolant via this valve. mine is original fit after 125k out of warranty now.
    told a new part with a "d" after part number is due in January. at a cost of 2000 plus
  2. #62
    Queenscliff, NSW
    I have a 2011 transporter, got the moo sound maybe two or three times over the last month. Worried now!!
  3. #63
    Queenscliff, NSW
    This is what I have just been quoted from Bill Buckle in Brookvale.
    part numbers related to my VIN but should be the same as most T5.1 vans.
    See attached schematic.
    1K0906627A Pressure converter, EGR GO 0 CO8E27 $141.50 Number 25
    7E0129458B Hose vacuum $106.50 Number 21
    7E0129458F Hose Vacuum $223.00 Number 20
    7E0129458A Hose Vacuum $62.00 Number 32
    I intend to check each hose if I can to try and identify which one or the valve is at fault. I'm getting the moo after engine shutdown.
    Attached Thumbnails Attached Thumbnails Mystery noise from under the hood-img_2426-jpg
  4. #64
    NSW
    Quote Originally Posted by Zebt View Post
    I have had the MOO for the last few years on shut down, apart from the small cow under my bonnet which sometimes needs an explanation to new passengers, we live in harmony with no other issues.
  5. #65
    Mar 2011
    Gold Coast QLD
    I've had the MOO for a year, intermittently, just shortly after taking off at traffic lights. Never at shutdown. Around 50 times approximately. Only once has it caused limp mode (confirmed with VAGcom) otherwise it doesn't seem to be a significant issue. Fingers crossed.
    - 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
    - 2008 Tiguan 5N 103TDI 4MOTION. Mods: RNS510 | Colour MFD | MFSW | LED tail lights | Mirror LED | Footwell LED
  6. #66
    Sep 2014
    East Brisbane, QLD
    Haha! It does sound like there is a cow in your car!
  7. #67
    Sydney NSW
    Quote Originally Posted by stevan View Post
    Why have you never had it fixed under warranty?
    Sent from my HTC_0PJA10 using Tapatalk
    2011 T5 4MOTION Duel Cab Optioned up.
  8. #68
    Queenscliff, NSW
    Changed the valve out, $150.00 easy to do, no moo for over a week now.
  9. #69
    NSW
    2010 model Revhead, out of warranty...
  10. #70
    NSW
    Hi Zebt, did you change part 25? Or can you let me know what to ask for so I can have a go. Thanks
