Page 9 of 10 FirstFirst ... 78910 LastLast
Results 81 to 90 of 93
Thread: Mystery noise from under the hood
  1. #81
    Mt Cotton
    Had to laugh today while researching the N75 valve on one site they describe it as the "Moo "valve a good sense of humour there . About to order one from OS not paying the local thieves the money they quote .
  2. #82
    Aug 2016
    NSW
    That is low kms!
    I'm up to 280k.
    2018 Crafter Runner
    T5.1 6sp manual.
  3. #83
    Sydney NSW
    Quote Originally Posted by LogicprObe View Post
    That is low kms!
    I'm up to 280k.
    I had my n75 i think it was called replaced and my van had done less than 25000km. This would be your issue
    Sent from my SM-G930F using Tapatalk
    2011 T5 4MOTION Duel Cab Optioned up.
  4. #84
    Sydney NSW
    That is low kms!
    I'm up to 280k.
    280km wow hows is your dpf holding up? Im on 135k
  5. #85
    Aug 2016
    South Yarra
    There are modified vacuum hoses with pulsation damper offered as a 'production change' from VW. They are $200 each plus fitting. I am going to try this before changing out the N75 "Moo Valve" as stated everywhere else online.
    The newer design hoses are a 'VW upgraded part' from VW's Technical Product Information sheet 2027520/13
    I'm looking to buy the set from the UK as they are half the price. See my other thread about OEM parts suppliers from overseas.
  6. #86
    Aug 2016
    South Yarra
    Hey Sunny where about's are you ordering your parts from?
  7. #87
    Feb 2008
    Adelaide,Oz
    removed the mounting bracket,removed hoses and sprayed WD40 into all openings on each of three valves i could see.
    Will see if it returns.
    Steve
    04 T5
  8. #88
    Mar 2008
    Mine has been noisey for a number of years (2008 Multi). I recently asked the dealer servicing it whether the N75 should be changed, They said unless it is triggering a fault code and not working, not need to change. I suppose the moo noise is an 'undocumented feature' on VW/Audi vehicles. I gave mine a clean a while back, there was no change, still the moo noise but functioning fine when tested on the 12 v battery.
    Regards,
    Scott
  9. #89
    Sydney NSW
    Mine was flucuating ever so mildy under throttle, you could feel it under slow driving in a carpark in first gear, this annoyed me. Since I had mine changed 5 years ago it has never come back.
  10. #90
    May 2012
    EdenHillsSA
    Please refer back to post #53 - and save your money on an unnecessary N75 valve replacement.
    Merry Xmas/Happy New Year to all.
    2011 T5 132kw 7spdDSG 4motion, '89 Citroen 2CV, 2006 Subaru Forester SG 5spd
