I have a 2011 transporter, got the moo sound maybe two or three times over the last month. Worried now!!
I have 2011 multivan is losing coolant via this valve. mine is original fit after 125k out of warranty now.
told a new part with a "d" after part number is due in January. at a cost of 2000 plus
This is what I have just been quoted from Bill Buckle in Brookvale.
part numbers related to my VIN but should be the same as most T5.1 vans.
See attached schematic.
1K0906627A Pressure converter, EGR GO 0 CO8E27 $141.50 Number 25
7E0129458B Hose vacuum $106.50 Number 21
7E0129458F Hose Vacuum $223.00 Number 20
7E0129458A Hose Vacuum $62.00 Number 32
I intend to check each hose if I can to try and identify which one or the valve is at fault. I'm getting the moo after engine shutdown.
I've had the MOO for a year, intermittently, just shortly after taking off at traffic lights. Never at shutdown. Around 50 times approximately. Only once has it caused limp mode (confirmed with VAGcom) otherwise it doesn't seem to be a significant issue. Fingers crossed.
- 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
- 2008 Tiguan 5N 103TDI 4MOTION. Mods: RNS510 | Colour MFD | MFSW | LED tail lights | Mirror LED | Footwell LED
Haha! It does sound like there is a cow in your car!
Changed the valve out, $150.00 easy to do, no moo for over a week now.
2010 model Revhead, out of warranty...
