Page 6 of 10 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 93
Thread: Mystery noise from under the hood
  1. #51
    Sydney NSW
    Well here is a update.
    I was refitted with my second EGR in as little as 4 weeks thanks to VW warranty on parts this was covered. After install techs still found check engine light on, they diagnosed faulty ECU. Asking VW for goodwill they supplied a new ECU and I just had to pay 2 hours labor. I was told a new ECU would have cost me $2900 if I was to buy one myself. Thank god I did not..
    I now have my VW back and all seems ok, but I have not really had a much of a chance to drive it, because I have spent the last 3 weeks in hospital due to a busted appendix, and a laparotomy and other complications.
    I sure hope this is the last of my VW issues for some time.
    I like to think my dealer has looked after me.
    2011 T5 4MOTION Duel Cab Optioned up.
  2. #52
    Mt Cotton
    Better talk to your doctor to see what sort of warranty they offer , after that sort of service job I would hope they could guarantee the repairs . Groan .
  3. #53
    May 2012
    EdenHillsSA
    Well here's my under-the-hood burping/farting/buzzing sound fixed (at LAST!) - and what it took.
    "...carried out diagnosis and found issue relating to tpi attached resonances on the boost pressure control valves; removed and replaced with vacuum hoses with updated vibration dampeners as required. Road tested all ok"
    Parts ... VW7E0129458N ... hose $28.67
    ... VW 7E0129458M ...hose $42.95 The prices reflect, I believe, a part-warranty reduction.
    LATE EDIT: don't know if it makes any difference but I should probably have stated that my van is a twin turbo.
    Mystery noise from under the hood-img_9132-jpg
    2011 T5 132kw 7spdDSG 4motion, '89 Citroen 2CV, 2006 Subaru Forester SG 5spd
  4. #54
    Mt Cotton
    Looks like a post operation result , lots of plumbing pipes left over the interns were let loose again .
  5. #55
    Mar 2011
    Gold Coast QLD
    Thanks for this info guys! My 2011 T5GP also has the mooing noise occasionally too ... I think once I even got the limp home mode too.
    Interestingly looking under the hood, the large silver part of the engine where the oil filter attaches to has a sticker saying "Pierburg Cooler, manufactured 2013" ... but the car is 2011..... why would there be a 2013 part in there? Has this got something to do with the EGR valve?
    - 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
    - 2008 Tiguan 5N 103TDI 4MOTION. Mods: RNS510 | Colour MFD | MFSW | LED tail lights | Mirror LED | Footwell LED
  6. #56
    Feb 2008
    Adelaide,Oz
    My 04 has started doing this farting noise intermittently, most commonly on startups, or even just turning the key(no start).Sometimes just sitting at the lights.
    Again, not always though.
    Had a quick perusal around the vacuum hoses,etc couldn't see anything obvious.Even chucked some WD down a hose thinking it's a sticky valve.Still occurred again.
    No loss in performance, no codes on my code-reader, vacuum EGR has been blocked long ago.
    Not too bothered yet, until it gets worse
    Steve
    04 T5
  7. #57
    Mar 2011
    Gold Coast QLD
    Quote Originally Posted by Rebuild View Post
    Same here
  8. #58
    Mar 2011
    Gold Coast QLD
    Quote Originally Posted by YellowLemon View Post
    Looking under the hood, the large silver part of the engine where the oil filter attaches to has a sticker saying "Pierburg Cooler, manufactured 2013" ... but the car is 2011..... why would there be a 2013 part in there? Has this got something to do with the EGR valve?
    I just checked the part number for this part mentioned above on the front of the engine where the oil filter attached, it's 03L 115 512A and described as EGR VALVE online. So obviously this Multivan has had the EGR replaced in 2013, phew...
    Links:
    VOLKSWAGEN 03L115512, oil filter bracket with: Cart Part Info
    VOLKSWAGEN 03L 115 512 (03L115512) Cooler, exhaust gas recirculation
    Kühler, Abgasrückführung 03L 115 512 | 03L 115 512 A Kategorien 03L 115 512 | 03L 115 512 A Kraftstoffaufbereitung 03L 115 512 | 03L 115 512 A Abgasreinigung 03L 115 512 | 03L 115 512 A Abgasrückführung 03L 115 512 | 03L 115 512 A Kühler 7.02756.07.0
    Car Part VOLKSWAGEN 03L115512, oil filter bracket with
    Costs 800 Euro new but it's on the front of the engine (engine code CFCA) doesn't look like it would be too hard to replace....
    Although the air intake seems to go behind the back of the engine which is naturally where I'd expect an EGR valve to be, so I'm not sure what's going on. Will just cross my fingers and hope I have no issues.
  9. #59
    Sydney NSW
    Links:
    There is a new revised version that is dated March 2015, I have this installed in my Transporter, and was told by Vw techs that all previous versions will fail, so they refused to put another one in my Vw until they could source this. I am told to change this you need to take the whole front end off and dump the oil and coolant. It's a big job.
    Sent from my HTC_0PJA10 using Tapatalk
  10. #60
    Mar 2011
    Gold Coast QLD
    Quote Originally Posted by REVHE4D View Post
    Ah yes oops I was thinking of Umai Naa's post on this thread about the EGR being at the back in the single-turbo engine
    Multivan T5.1 CEL "Engine Fault Workshop"
    Seems like the biturbo CFCA engine has been getting 'new and updated' versions of the EGR valve every few months ... have a read of the thread above
