Why would a Multivan be different to a Transporter?
I wouldn't bother with Hayman Reese anyway.
Hi, I'm interested in fitting a towbar to my T5 Multivan. Hayman Reese have one for a T5 Transporter but the MV is not listed. My VW agent wants over $800 to arrange for a local guy to fit. Does any one know about the multiplex wiring and the kits required to fit towbars to these vehicles?
Thanks
T5 multivan & transporter are the same. Here's some info, sorry it's in Finnish & Swedish but the diagram shows how it goes together. Kovil is one of the largest towbar manufacturers in Europe. Fitted one to father-in-laws Bora a couple of months ago.
http://www.kovil.fi/pdf/56321A-FS%20.pdf
A friend has a Caddy who had the same problem.
He was quoted $1200 for the tow bar. The solution was to source the electronics from the US for about $100, and then fit a Hayman Reece bar with a friendly auto electrician who knows about the CAN bus system to install the electrics. If interested I can find the link for the electronics.
I would also like to do this to my T5.
Rod
Golf V TDI 2005 - SOLD
Volvo C30 D5 - I've got a hat as well!
Multivan Highline T5 TDI 4Motion 2005
Hond Civic VTI 2001
You just need to get yourself a can bus ECU which will be a swap . Then get the towbar fitted .
Hayman reece make the factory units for Australia and NZ only
T5 Transporter = MV
$800 supplied and fitted is approximately what the VAG kit should cost (fitted by a third party including CAN bus "programming"). Dealers quoted me from $1200-1600 from memory. The main difference being the labour charge.
It was because of this I did not bother with Hayman Reese-no cheaper than VAG.
You will get the usual bullsh@t from the dealers about CAN Bus programming - does the quote "and the monkey flips the switch" ring a bell?
On a T5 the CAN bus tow bar "switch" (flipped via VAG-COM) is more to do with acknowledging the extra load of the second tail light set so a blown bulb fault is not registered than anything else.
I got sold a couple pork pies about a different shift pattern being utilised when the tow bar electrics are engaged. This was another shovel load of bs as the vehicle cannot differentiate between a bike rack, a trailer or a fully loaded caravan...I verified this when I used my own Ross Tech VAG-COM unit...
The harness was cheapest from VW when I went looking. A lot of after market tow bars in Europe actually bundle a VAG harness rather than make up one - AUD100-200 from memory. Search The Brickyard forum T5 posts for a detailed summary of my Kombi Beach install
Cheers, MM
PS I just remembered one other thing the VAG COM "switch" can do - it turns off the rear ultra-sonic park sensors so you do not get a false positive with a trailer attached.
EDIT: I refer to a hitch receiver (square hollow section tow coupling) not a fixed tow bar. This will make a difference to price. A fixed tow bar should be cheaper.
Last edited by MultiplexMan; 01-07-2008 at 06:22 AM. Reason: Hitch receiver not tow bar in my case
??? Not required on my T5 Kombi Beach and any of the T5 Transporters/Multivans I have seen to date. Sure you aren't thinking about cruise control and the Highline ECU?
I actually compared these side by side - they may come out of the same factory (have to look at the manufacturer's stamp on mine) but they were cosmetically different. I remember the height of the hitch receiver ended up being slightly different...nothing much in it in the end though.
Cheers, MM
Bugger! I just noted the date of the original post - 2006.
