Results 1 to 10 of 14
Thread: Multivan T5 door lever broken....?
    Jul 2010
    Geelong West, VIC
    Hi there,
    Wondering if anyone has any tips or tricks for prying the interior panel off the drivers side door? Please?
    The door lever is broken (have to wind down the window to unlock the drivers side door) and seems to have unhooked itself from the cable. Just wanted to have a look at what was going on to see if it's fixable.....
    Cheers!
    Adelaide hills, SA
    I'm not sure if you can remove the door trim from the inside with the doors shut.
    The dealers, crash repairers and the locksmiths could have more ideas how to open it.
    Also consider take it to the dealer rather than damage the door trim DIY, it can be cheaper. (but get the quote first, just in case that they would need to brake the door trim anyway)
    Dec 2008
    Sydney Australia
    Quote Originally Posted by minniemousey View Post
    Hi there,
    Cheers!
    I have had this part replace twice under warranty, I know that the door card is a large plastic part and were it breaks is a very small section.
    Next time it breaks i am going to get the new part reinforced.
    Can help you on pulling it a part but know how frustrated you must be.
    The VW Bug
    2010 Golf 2.0 103kW TDI Manual White
    2011 Multivan 2.0 132kW TDI Sliver
    2018 Multivan 2.0 TDI White
    Jul 2007
    If I understand the OP, you can still open the door but need to use the outside handle?
    The UK Brickyard forum has a detailed step by step procedure for removing the trim. The only "tricky" bit is the flimsy cover on the interior door pull. Be very careful taking it off as it is easy to snap...
    How to remove Door Card/Trim - Pics - The Brick-yard
    Jul 2010
    Geelong West, VIC
    Maybe I wasn't clear...I can get the door open. I wondered if anyone had any tips for getting the door trim off to see what was happening with the lever? Cheers!
    Adelaide hills, SA
    Naah, you were clear, I didn't read it correctly.
    Sent from my HTC Desire using Tapatalk
    Jul 2010
    Geelong West, VIC
    Wink
    Multiplex man - thank you!!! Transporter - I said unlock when I meant open the door! Thanks for your help guys.
    Feb 2009
    COOLANGATTA
    Mines a ancient model but my interior handle just clips out from the rear just pry a little at the rear top and bottom and it pulls out to the rear im sure youl find its broken try this as a first step its a lot easier than removing the whole card .pugs
    Dec 2008
    Northern Suburbs
    ive seen a broken one of these and their really isnt a way to fix it, the area that breaks is plastic welded to the whole door card, it wasnt my car so i couldnt find a way that would last and work like standard other than replace the panel
    Dec 2008
    Sydney Australia
    Quote Originally Posted by PeDiES View Post
    Before it breaks again and i run out of warranty, I am thinking about bonding some plastic to either side of where the cable it clipped in, do you think that this would work ???
    The VW Bug
