Results 1 to 10 of 14
Thread: Multivan T5 2005 Sunroof leaking HELP!!
    Nov 2017
    BATHURST NSW AUSTRALIA
    Question Multivan T5 2005 Sunroof leaking HELP!!
    Just purchased a VW Multivan, 2005. The sunroof leaks! The mob I purchased from says no warranty on old car. Went to local VW dealer for repair, cost $ 165 to diagnose leaking sunroof. Quote $5500+ to fix!! I can't afford that, so will try myself. Does anyone know where the sunroof rear drain tubes are located and where they drain to... I can sort the front ones out, just needing help/ diagrams/ anything to fix the back drains. Thank you
    Mt Cotton
    Hi Lauren I fit and service sunroofs so I can offer some help for you free of charge [unlike the dealers ] . Ok a couple of questions is the sunroof a factory or aftermarket one ? does it slide back internally or over and outside the roof . If unsure send me a couple of photos to my message box . Where do you see water coming into the van ? , next a simple test for the drains which is the first step to test . Open the sunroof up with the rear of the van facing downhill , there should be a housing which the water can get into pour some water on each side into the housing . The water should run to the rear and then come out onto the road below the van , if there is no water coming out it would indicate a blocked drain . Also do the same test for the front drains with the front facing downhill this time . Now if any drains are blocked the water most likely depending on how the roof slides will start to fill the sides of the housing until it overflows into the roof trim . Now as I have never had to repair any of the factory sunroofs the location of the drains will be a bit hard to tell . If one side is letting water out I would suggest checking the similar location on the other side to find the outlet . VW have over the years has used a system that will block so you need to check this , at the very outlet point they sometimes use a self sealing rubber fitting to stop any dust getting back into the pipes . As I said if one side is working do avisual check to find what you are looking for on the side that is blocked , if it has one of those rubber fittings you can easily unclog it with a small screw driver to dislodge and build up of muck . If this is the case pour more water into the housing to flush out any more dirt . DO NOT let anyone tell you its a $5k job to fix give that delaer a wide berth . The next one could also be an issue VW again have used some pretty dumb ideas for their sunroof drains , we get a lot of problems with VW Beetles and especially VW Tiguans , the problem is they do not clamp the hoses where they join the sunroof housing and they WILL leak at that point see photo of what we do to fix the problem but you will need to remove part of the roof trim to get to the hoses if they are like the Tiguans etc . We use a wide cable tie or a hose clamp to fix the hose to the frame , sometimes you need to put some silicone sealnt around the next joint as they can leak as well , its just ashocker of a design from VW . Now next you could take the van to Webasto Sunroofs in Kirrawee they can check for you if needed , ask for Norm Kaj . Multivan T5 2005  Sunroof leaking    HELP!!-20171106_102648-jpg
    Aug 2016
    NSW
    Sunny is a good man to have on the team!
    2018 Crafter Runner
    T5.1 6sp manual.
    Apr 2014
    Chelmer, Queensland
    Multivan T5 2005  Sunroof leaking    HELP!!-like-jpg
    Nov 2017
    Thanks Sunny43.5, It appears to be a factory sunroof- opens internally. So far the water leaks have appeared above passenger side sliding door, Passenger side front, coming out through pillar where the grab handle is. Have tried having front of car on slope cleaned out tracks , found front drain holes. Put water into channel to drain on drivers side front, some water came through wheel arch onto ground, then water started coming through into cab from under dash and water in rubbers on door step. Then tried water into channel, passenger side, water into cab, coming out through pillar where the grab handle is. Tried hot soapy water, degreaser, tried pushing a tube down and blowing, to no avail, could only get tube down as far as grab handle....Blocked. The front drain holes are only about 5mms. Haven't yet tried the van downhill backwards... will do that on the weekend....
    Mt Cotton
    can you send me a couple of photos showing the switch and then the outside of the roof . eastcoastsun@optusnet.com.au
    Nov 2017
    I'll get onto it this arvo
    Jul 2016
    Sunny/Howard.
    I have to say you are a champ, its good to have someone with your knowledge on the forum and helping others.
    2017 VW T6 3200KG GVM LWB 132kW 7 Speed DSG (Campervan Conversion)
    Mt Cotton
    Thanks guys I believe that any info I can share with subjects close to my heart will help Forum members sort out problems , I know I have also received heaps of help from others so it make sense to help with subjects I do know about .
    May 2012
    Nowra, NSW
    Thanks for the info, my '05 multivan had a damp floor and water on the floormat this morning after some good rain overnight. I opened the sunroof and jigged some wire down the tubes. Put a little water in the sunroof scupper and it seemed to not want to drain away in a hurry, so it looks like I will be looking further into the drain lines, many thanks for the Pic Sunny43.5 a great insight as to what to look for.
    Ades
