My wife called me this afternoon telling me the Van is doing strange things and this error came up. She limped it home where it's now parked...
I called the local dealer who says they have no space at all until next Tuesday and no loan cars available until at least then. I did point out that me keeping it at home was sort of pointless when I couldn't drive it and asked if there were any options to get it looked at sooner... the answer was an unconvincing "not really"... I plan an dropping it down anyway in the hope they can find 5 minutes spare to at least make sure it's not a random brain fart of the computer.
Of course, that was the idea before I got home and had a chance to scan it. Seems the CEL is on when you start it, then if you attempt to drive at all (read even reversing out of the driveway), the coil light (looks like a twisted wire) starts flashing and the Engine Fault Workshop message is displayed as white text. Of course the biggest problem is that the turbo does not seem to be spooling up at all.
So this is the results of the scan and I'm wondering WTF? Any suggestions?
Code:
(Some non important lines where there is no fault have been removed to fit it in this thread)
Wednesday,20,June,2012,18:01:37:35849
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 6N0
Scan: 01 02 03 08 09 10 15 17 19 25 69
VIN: WV2ZZZ7HZAHxxxxxx
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CCHA) Labels: 03L-906-022-CAA.clb
Part No SW: 03L 906 022 GF HW: 03L 907 309 K
Component: R4 2,0L EDC H32 9130
Revision: 26H32--- Serial number: 00000000000000
Coding: 01254012232400080000
Shop #: WSC 23117 959 96126
ASAM Dataset: EV_ECM20TDI01103L906022GF 002008
ROD: EV_ECM20TDI01103L906022GF.rod
VCID: 6FE724D2B6862D1
6 Faults Found:
11901 - Manifold Pressure / Boost Sensor (G31)
P0236 00 [032] - Implausible Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 52725 km
Date: 2026.14.19
Time: 17:10:18
4124 - Sensor Reference Voltage B
P0651 00 [032] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 52725 km
Date: 2026.14.19
Time: 17:10:02
4881 - EGR Valve (N18)
P1440 00 [032] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 17
Mileage: 52723 km
Date: 2026.14.19
Time: 17:06:31
9120 - EGR Sensor 1
P046C 00 [100] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 52720 km
Date: 2026.14.19
Time: 16:15:59
4891 - EGR Valve (N18)
P0403 00 [168] - Malfunction
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 52719 km
Date: 2026.14.19
Time: 16:13:29
4892 - EGR Valve (N18)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 52719 km
Date: 2026.14.19
Time: 16:13:25
Readiness: 1 2 0 0 0
Address 02: Auto Trans (J217) Labels: 0BH-927-711.clb
No fault code found.
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 E HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0103
Revision: 00H43001
Coding: 108724AD09A8089924A2907AAA6216
Shop #: WSC 02756 790 49152
VCID: 346DEBBE97204E9
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 134
Mileage: 52725 km
Time Indication: 0
Date: 2026.14.19
Time: 17:10:02
Freeze Frame:
Count: 2048
Count: 17
Count: 8241
Count: 4
Address 08: Auto HVAC (J255) Labels: 7E5-907-040.clb
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 B HW: 7H0 937 087 B
Component: BCM T5GP H+4 H46 0207
Revision: BO046001 Serial number: 0156 044100618
Coding: A0A0293A0E61240393204000242B8FD40080410F60040000300000000000
Shop #: WSC 02756 790 00000
VCID: 336FE8A2922E491
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 090210 05 54 0403
Coding: 03302E
Subsystem 2 - Part No SW: 7E0 959 801 B HW: 7E0 959 801 B
Component: J386__TSG_FT 002 3310
Coding: 010000
Subsystem 3 - Part No SW: 7E0 959 802 B HW: 7E0 959 802 B
Component: J387__TSG_BT 002 3310
Coding: 000000
Subsystem 4 - Part No: 7E1 951 171
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 5 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
Subsystem 6 - Part No: 7E1 951 171
Coding: 000000
1 Fault Found:
03587 - Control Circuit for Starter Lock Lock
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 2
Fault Frequency: 1
Reset counter: 126
Mileage: 52394 km
Time Indication: 0
Date: 2026.14.13
Time: 09:57:55
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
End ---------------------------------------------------------------------
