I fitted 3 Rola racks on my first T4 normal wheelbase as the windsurfer & gear spread the load along the length of the board without damaging the roof I fitted them myself on the outside of the channel in the roof as I could damage the paint if they were put down in the channel ,
Mounted With staino self tapper bolts & stickaflex they were not wind noisy I used the track system 500mm long each so they could be moved if needed or taken off real quick with the security studs that was part of the setup . .
Heavy loads were no worries as I would move the load over the rear on 2 racks & plywood sheeting to carry the load .
I miss them now with the Ex ambo high roof guess I cant have everything .
Long wheel base & stand up room is a great thing .
TC
