Results 1 to 10 of 14
Thread: Multivan Mats
    Oct 2009
    SydVegas
    Old thread, but exactly what I was looking for - I would appreciate a part number.
    Also - is that just for the area between the captains chairs and bench seat, or is there one also for the cargo area behind the bench seat (which I would think is harder given the back moves)?
    Sep 2011
    Tennyson Pt, NSW
    I have a full mat set that was option when purchased last sept. It does not go behind bench seat.
    One word of warning, if you have multifunction, the table has very little clearance over original carpet and would not run over the top of middle runner of carpet set. We had the middle runner cut off, edged and velcro strips added to strip and main mat - we can now easily take out middle runner when we have the table installed.
    _________________________________
    2011 VW Multivan Comfortline 132kw TDI400
    2013 Golf TDI 2.0
    Oct 2009
    SydVegas
    Ah, that's interesting - I'm also going to get the rubber mats for the front and, if possible, up to row 3 (I don't have the multifunction table). Tennysonian, how does your carpet set fit around the captains' seats and how far does it go towards to the bench seat?
    For the boot, my further research shows there seems to be 3 options:
    A reversible boot mat (part 7E5 061 210), that I've seen also described as being moulded foam.
    A boot liner (part 7E5 061 160)
    A boot tray (part 7E 5 061 161).
    I can't find dimensions anywhere online, but the pictures look like the reversible mat is deeper than either the liner or tray. Has anyone got one who can shed light on the depth? (I'm also trying to get more info from VGA directly).
    May 2010
    Kilmore, Vic
    Something I find cheap and easy, Bunnings sell polypropylene matting, I think it's classed as marine carpeting
    I use the dark grey one, fairly thin and very durable.
    I put a fair bit of gear in the back (captains seats out and bench foward to the middle) and it works brilliantly
    You can buy a few metres of it and cut a few different shapes depending on where you're going to place the seats
    Personally, I just leave the original Multivan mat in the passenger front, a bloody thick durable rubber one under me, and nothing in the back when I'm carting folks around. I find the carpet inside these vans comes up easily with a quick vac and a spot clean
    M
    Mar 2012
    I was going to suggest marine carpet as well. Very durable and handles wet shoes very well.
