Results 1 to 10 of 11
Thread: Multivan Auto Transmission
    Dec 2008
    Sydney Australia
    Hey Vanners,
    has or is anyone having issues with a rough changing gear box.
    I dont drive my van to often as wifes prime mover for the rug rats.
    Any way I have notices rough change from 2nd to 3rd.
    It also seems to hold all gear too long on both change up and change down.
    This may be part of my problem with high fuel consumption.
    VW say there is no software dates to fix this issue.
    Any Ideas ?????
    The VW Bug
    2010 Golf 2.0 103kW TDI Manual White
    2011 Multivan 2.0 132kW TDI Sliver
    2018 Multivan 2.0 TDI White
    Aug 2007
    Forget the software upgrades, have you been back to VW??? This can be a few things, simple adaption, or even an engine fault( eg throttle etc). Get them to run a data dump on your Van just to make sure. It is an adaptive gearbox ( constantly learning) so it will be relearning your driving style as opposed to your wifes.
    Jmac
    Alba European
    Dec 2008
    Sydney Australia
    Thanks Jmac.
    I did got to the dealer and they spoke to VW Australia on the issue they came
    back that there was nothing that they can do.
    Thanks for the info on Adaptive Auto.
    I will go back to them as im still not happy with the box.
    Thanks,
    The VW Bug
    The VW Bug
    Adelaide hills, SA
    Take for drive another van like yours to see if it's the same.
    Canberra
    Here is a thread from the UK Brickyard forum about problems with a (high mileage) T5 auto. Not sure if it is the same as your problem or not.
    http://www.brick-yard.co.uk/forum/ti...opic37033.html
    Aug 2008
    "Theres nothing we can do" WTF!!!! seriously they sound like a bunch of morons. Car is under warranty, car has problem....they MUST fix it. If it means a new gearbox then so be it. You fuel consumption figures alone show there is a problem with something and it needs to be fixed!!!
    Have they had it plugged into the computer to find all fault codes? Maybe you should try another dealer.
    2014 T5.1 Multivan Tuned by Pendle Performance Australia
    Nov 2007
    QLD
    reset
    I read on one of the forums which I can't find now that you can reset the auto to default so it can learn your habits from scratch.
    I think the procedure was to hold the accelerator on the floor then turn on the ignition for >=10sec then off again.
    Try searching the fixes and faqs on here and the brick-yard.
    Brian
    Aug 2007
    Agreed mate
    Alba European
    Feb 2008
    Adelaide,Oz
    to reset the Trans Control Module (TCM) follow these steps:
    1. Turn ignition to ON (do not start engine)
    2. Press the gas pedal to the floor till it clicks
    3. Hold the pedal for 15 seconds
    4. Release pedal gently
    5. Turn Key to Off
    6. Start engine and drive as normal
    By resetting the TCM, it will re-adapt to your driving style.
    Steve
    04 T5
    Aug 2007
    Absolutley right guys thats where i was going with the adaption. If all else fails you can readapt with VCDS (VagCom). Like some have metioned it should be the first thing the Dealer should try instead of saying they cant do anything, easy out i reckon. If they( the dealer) cant get it right then they should be looking into getting it right IMO.
    JMac
    Alba European
