Results 1 to 7 of 7
Thread: Mounting Roof LCD DVD
    Dec 2008
    Sydney Australia
    Hello Vanners,
    Has any had experince fitting a roof mount LCD/DVD ??
    I am putting in a 10 inch LCD and want to know how to remove headlining.
    Is there any close 12v Power source up there ??
    Thanks,
    Thebug
    The VW Bug
    2010 Golf 2.0 103kW TDI Manual White
    2011 Multivan 2.0 132kW TDI Sliver
    2018 Multivan 2.0 TDI White
    Adelaide hills, SA
    I will look in the manual when I have a bit of free time.
    Once the lining is off you'll be able to run correct wire dia. for powering the unit. Interior light has 12V on it but I'm not sure if the wire is good enough for that unit.
    Dec 2008
    Sydney Australia
    Mr Tporter any luck getting some info for me?
    The VW Bug
    Oct 2010
    Perth, WA
    Keen for any information too as I will be installing a 15" DVD unit on the roof soon.
    May 2010
    Kilmore, Vic
    Anyone installing a screen and rear projector???
    M
    Adelaide hills, SA
    Quote Originally Posted by thevwbug View Post
    Sorry mate I forgot.
    Send me PM with your VIN (my T5 is just a van so I can't use it) and I have look in Elsa.
    Mt Cotton
    I have fitted a 15 inch dvd player flip down screen to my sons T4 all thats needed is a an accessory wire which you can pick up supply from spare fuse point in fuse box or via a relay using the accesory wire at the back of the radio , you can use the light wire for a built in light if it has one . The standard head unit was replaced with a 7 inch fold out single din screen model which I bought from a Chinese supplier unreal unit standard with am fm radio plays dvds hd tv tuner ipod connection bluetooth for phone with music streaming via bluetooth usb connections , built in GPS with picture in picture function and touch screen operation also has iphone like function you slide your finger over the screen to change functions also has extra outputs and inputs for rear screen and back up camera facility for the price of $350 delivered
