Not likely any stagnate water as the air con drains out constantly through drainage tubes to the road , if you run the air con you should see some water dripping from the underside of the van . I could not see them getting in from outside through vents as they would have to bore holes through the air filter . Real strange one I suppose you keep the windows shut when parked ?
