The older T5 (2.5L 5cyl single turbo) engines are good IMO. No timing belt, all gear driven motor.Mines still running strong, only done a waterpump. They do 180km/h flat out
(128KW)
Watch the T5 tiptronic 6 spd autos though(up to 2010ish). They are sometimes problematic, as VW early on, said these were a lifetime fill, no oil change or filter required ever( Yeah...right!!).
My tiptronic 6spd auto T5 had a full gearbox rebuild, in stages, at 180K km, costing all up about $9K. Bank on around $6-7K for a full rebuild if required.
I did my own fluid and filter changes and still got probs.
Cue, Sunny ...
Don't think you can get manual T5 multi's. However if you like a T5 auto at a price, see if it's had the auto serviced regularly, filters especially, not just drain and refills. Check for any slippage or as its called "flaring"(burnt clutch/fibre plates in gearbox), if you test drive
Then buy an external air/oil cooler to keep gearbox temps down.
With the T5.1's (2010 onwards?) avoid the CFCA motors, i think, for the oil consumption issue.Faulty EGR coolers collapse and destroy the bores and ring sealing. Search on here for it, plenty of posts about it.
Haven't read of probs with T5.1 auto gearboxes
