Results 1 to 6 of 6
Thread: MFSW & Cruise control help
    Mar 2010
    auckland NZ
    I just got a new T5.1 transporter and have fitted cruise, front fogs and MFSW but my BCM doesn't support those functions. (no pins on the board where those wires go)
    Does someone here have those parts installed on their van and if so could you post up what the part number of your BCM is please?
    Just trying to figure out which BCM I need to get, my old one is a 7H0 937 086B
    IN2VWS Guest
    OK....I think I figured out the 3rd letter (module), but what is the BC?
    Mar 2010
    auckland NZ
    Quote Originally Posted by IN2VWS View Post
    Body Control Module or J519, controls all functions like lights, central locking MFSW etc etc etc.
    Found under central electronics (09) in VCDS
    IN2VWS Guest
    Does this help?, from my MY11 Transporter:
    Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
    Part No SW: 7H0 937 087 D HW: 7H0 937 087
    Component: BCM T5GP H+4 H47 0221
    Revision: BO047001 Serial number: 0347 279100767
    Coding: B8A0303A0E33203300280010342B8CD50080430F6004400030 0000000000
    Shop #: WSC 02734 790 00000
    VCID: 356A902925D1
    Part No SW: 7E0 959 801 B HW: 7E0 959 801 B
    Component: J386__TSG_FT 002 3311
    Coding: 010000
    Part No SW: 7E0 959 802 B HW: 7E0 959 802 B
    Component: J387__TSG_BT 002 3311
    Coding: 000000
    Part No SW: 5K0 959 542 HW: 5K0 959 542
    Component: E221__MFL-TAS H06 0010
    Coding: 830000
    No fault code found.
    Mar 2010
    auckland NZ
    It does thanks, also what mhz is it?
    On your flip key it should say what frequency it is, usualy written where the blade tucks into the key.
    Would also be interested to hear from anyone else who has done this and what module they have, just covering my bases before I go out and buy a new control unit.
    IN2VWS Guest
    434Mhz
