Results 1 to 10 of 16
Thread: MAF to ecu help needed
    Jul 2017
    Raymond Terrace, NSW
    MAF sensor
    I'm after a MAF sensor part No: 038 906 461 for a 2002 T4 2.5 TDI. If anybody has one they would like to part with can they please let me know. Thanks.
    Mt Cotton
    Whilst a second hand one might be an avenue to explore there are several new ones on Ebay from the US or Uk for less than $100 just put that part number in agoogle search with the VW letters after and you will be presented with avariety of places to source one .
    Jul 2017
    I tried another MAF sensor in my '02 T4 TDI today but fault is still showing on the vagcomm done by Pete at Newcastle VW Center. Now I need to check the wiring. So would anybody know which pin connects the MAF to the ecu please? After replacing the MAF it cleared the fault code, and it does run a bit better power wise but the fault showed up again. Any help at all would be appreciated in regards to this. What it seems I have to do is use an ohm meter to trace the wire and replace it by splicing into the wire both ends and bypassing the original one. I'm hoping I can do it without taking it to an autoelectrician and save me some costs. I'm only on a disability pension so funds are hard to come by after repairs I already done to it.
    Adelaide hills, SA
    Maf sensor pin
    3 goes to pin 49 in ECU. wire colour Orange/brown
    4 goes to pin 30 wire colour white/silver/vi
    5 to pin 68 orange/Vi
    2 connects to fuel injection timing solenoid which connects to ECU
    May 2006
    Adelaide South Australia
    As these vans get older, the wires running in the sheath along the top of the engine can rub through the insulation causing all sorts of problems.
    Numerous Mk1 Golf diesels
    Jul 2017
    Thanks guys ��
    Jul 2017
    Got a used one from Camden GTI but it still shows up as error so now gonna get a multimeter and test the wiring. Bummer though as I was hoping this would fix it...
    May 2006
    Quote Originally Posted by Fossil View Post
    This is the next step I would do, but would add to carefully remove the wires [not disconnecting] from the sheath inspecting the insulation on all the wires for any damage. You won't need an auto electrician, it's DIY job.
    Adelaide hills, SA
    Quote Originally Posted by jets View Post
    Yes it is as long as it really is a maf sensor.
    May 2006
    A word of caution here. There has been several reports on the T4 Forum of people buying the cheaper brands on Ebay only to find they needed to replace them with better quality ones like the Bosch. I replaced one on my first T4 [Bosch] that wasn't cheap but work perfectly for at least the many years that I owned it.
